Oil filters
Old May 16, 2003 | 06:07 AM
strokeman's Avatar
strokeman
Oil filters
I have a 1997 sport with a 4 L sohc engine. Is it worth the extra money to buy a non-flow back oil filter. one similar to what Volvo uses that has a one way valve in it so some of the oil remains top side?
Old May 16, 2003 | 06:19 AM
Bob Ayers's Avatar
Bob Ayers
Oil filters
Just use the stock Motorcraft filter, and you will be fine!!
By all means, NEVER use a Fram!!
Old May 16, 2003 | 06:36 AM
SplashMan's Avatar
SplashMan
Oil filters
Why is that? I've never had a problem with them.
Old May 16, 2003 | 12:08 PM
strokeman's Avatar
strokeman
Oil filters
why not fram?? I have used them off and on for years. my 1987 F150 has over 150K and my 1995 has 105K. not arguing just wondering why you beleive it.
Old May 16, 2003 | 12:39 PM
Bob Ayers's Avatar
Bob Ayers
Oil filters
If you do a search on Fram oil filters, you will find a lot of posts
with problems with Fram oil filters. I personally had a bad experience with one years ago also!!
Probably the most common symptom with Fram oil filters is valve
train / bearing noise on startup due to the poor anti-drain back
valves on Fram filters.
You can also check out this report:
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Old May 16, 2003 | 12:52 PM
strokeman's Avatar
strokeman
Oil filters
ok I beleive you- but you must use the filters with the valve so I assume you support those type of filters. NAPA makes one - is it any good
Old May 16, 2003 | 12:53 PM
strokeman's Avatar
strokeman
Oil filters
all motorcraft don't have the valve do they????
Old May 16, 2003 | 12:59 PM
Bob Ayers's Avatar
Bob Ayers
Oil filters
Yes, that's why I originally said to stay with Motorcraft...
Old May 16, 2003 | 01:01 PM
strokeman's Avatar
strokeman
Oil filters
thank you very much. again thanks
