Help, 2001 Excursion no start
Old Sep 15, 2012 | 07:35 PM
BigAlsPSD's Avatar
BigAlsPSD
I would try to pull the IPR and at least clean and inspect. This is really about all you can do without proper diagnostic tools.
IPR Rebuild - Large Pics.pdf
Old Sep 15, 2012 | 07:53 PM
Holzarbeiter2's Avatar
Holzarbeiter2
Attachment 61344
Thanks for the instructions, I'll give that a try
Old Sep 16, 2012 | 10:04 AM
lhud's Avatar
lhud
Hey, do not forget to check the coil resistance on the IPR - should be 10.2 ohms. If way over or under, coil is likely bad and the mechanical parts on the IPR could be good.
Old Sep 17, 2012 | 11:14 AM
Holzarbeiter2
I get 10.7ohms what is considered way over or under?
Old Sep 17, 2012 | 11:38 AM
Bigtruc's Avatar
Bigtruc
I'm having no start issues with my truck also & got 10.8 when testing my coil. I replaced mine with one off of a working truck with no luck, the working truck tested 10.7. From what I've been reading as long as the ohm reading holds steady at around that 10-11 range it is good. If it fluctuate's up & down then it is most likely bad
Old Sep 25, 2012 | 04:27 PM
Holzarbeiter2
Well here is an update.
The truck still does not run, it has coughed a couple of times.
I get smoke from the tail pipe, have 10.5-10.8 volts at the pcm during cranking.
I have cleaned the IPR and tested the coil, tested both batteries and they are good, replaced the fuel.
Anything else I can try before I ship it of to the shop?
zay1016
30
May 30, 2016 09:15 PM
Diesel cat
Jul 25, 2015 11:08 AM
wildstang
Jun 27, 2012 10:25 PM
VegasFMF
43
Jan 14, 2009 08:14 AM
mzeigler27
Oct 31, 2008 01:18 PM
