Bouncing Oil Pressure Gauge
Old Sep 14, 2012 | 02:27 PM
wjjarvis84's Avatar
wjjarvis84
Everyone,
I noticed today in traffic my in dash oil gauge dropped a couple of times and the Check Gauges light came on. The gauge dropped and was showing no pressure for only a couple of seconds each time it did it. Each time it dropped I tapped on the gas and the needle when back up and the check gauges light came off.
What could be the cause to this? bad sending unit? I just had my oil change at the dealer. I also have a scangauge II is there a gauge to show oil pressure? From my understanding the scangauge will not show high pressure oil, but will it show low pressure oil?
Thanks!
Old Sep 14, 2012 | 02:37 PM
npccpartsman's Avatar
npccpartsman
It will actually show high pressure (ICP) and not low pressure. The dash gauge is nothing but an idiot light with a needle. Most likely you have a bad connector or bad sending unit. If you actually had NO LPO then the truck would shut off.
Old Sep 14, 2012 | 03:25 PM
cheezit's Avatar
cheezit
what year is the truck. if you have the early style swashplate then the pump may have sit the ball outor it could be the sender. if its the later style pump then sending unit would be the casue.
Old Sep 14, 2012 | 04:06 PM
wjjarvis84's Avatar
wjjarvis84
That's makes sense, thanks for your input. Isn't ICP Injector Control Pressure?
Old Sep 14, 2012 | 04:07 PM
wjjarvis84's Avatar
wjjarvis84
The truck is a 2003 F350 superduty.
Old Sep 14, 2012 | 05:50 PM
cheezit's Avatar
cheezit
you have a swash pump. If the ball has come out of the pump you will have the same issue. basicly the low side pump cant keep pase and is draining the low side system.
the easy way to figure out what one it is is to install a base oil pressure gauge and go drive it. Or you can just replace the sender as its much cheeper to do and see what happens. after replacing the sender if the concern is still there you need a pump.
sandmn1010
Dec 13, 2009 12:26 PM
imfinethanx
Modular V8 (4.6L, 5.4L)
Jan 18, 2008 12:02 AM
dumyfou
1983 - 2012 Ranger & B-Series
15
Jul 6, 2007 07:29 PM
nibiru
Feb 20, 2006 07:08 PM
rdw516
Nov 22, 2005 05:31 PM
