352 Pipe Flange
My 70 bump uses single doughnuts on each side and both manifolds incorporate a recess.
Interchangeability can be both a bane and a blessing.
Your 'custom adapter' could be the original heat riser valve that had the flapper removed, holes welded up. Heat riser valve: Two different gaskets, one's a donut, t'other is flat.
Because of the heat riser valve, the 1965/67 F100/350 352 left exhaust manifold (C5TZ-9431-A) is different than the 1968/76 F100/350 360/390 left exhaust manifold (C8TZ-9431-B).
Right exhaust manifold (DOTZ-9430-A replaced C5TZ-9430-A) same: 1965/67 F100/350 352, 1968/76 F100/350 360/390.
FE Passenger Car exhaust manifolds are different from F100/350's, as they have the exhaust collectors in different locations.
Look on the right & left exhaust manifolds for the cast ID numbers, post what they are. 'Custom adapter' may have an ID number cast onto it, will include 9A427.
HIO Silver: Best case scenario: Confused TBF squadron leader flew east past radio range out into the Atlantic till squadron ran of of gas.
Witnesses on a boat said Martin Mariner seaplane sent out to look for missing squadron exploded in mid-air. Mariners were known as "the flying gas tank." It only took one spark: BOOM!
But, what happened to the collier USS Cyclops? An enduring mystery since 1918, as no one knows what happened to it. Calm weather, U-boat records examined after WWI ended showed no involvement.
USS Cyclops' sister ship USS Jupiter converted, became the USN's first aircraft carrier USS Langley (CV-1), known as "The Old Covered Wagon."
). Thanks for your input. Curious to find out some of the origins of my modge podge 352.
ID: R/S C5TE-94 would be followed by 30 .. as every V8 car/truck and etc right exhaust manifold since 1932 is Ford basic number 9430.
ID: C5TE-9430-C right manifold originally was Ford part number: C5TZ-9430-A which was replaced in 1970 by: DOTZ-9430-A
When dies are worn, letters and numbers take on appearances of something else.
ID: D2TE-9431-AA = Ford part number: C8TZ-9431-B ~ 1968/76 F100/350 360/390.
