air cond question
Old Sep 13, 2012 | 12:40 PM
dh1978's Avatar
dh1978
air cond question
does anyone know the positions of the high and low pressure stems that are located at the hi/los pressure valves? i believe there are three positions: charge,regular oper, and closing off system, but im not sure and not sure about which way to turn stem. any help would be welcomed..thanks
Old Sep 13, 2012 | 09:26 PM
79_FORD_F-100's Avatar
79_FORD_F-100
Turning the fittings all the way in is for servicing or removing the compressor. All the way out is for using the a/c. As for charging most systems that I service I have the fittings all the way out.
Old Sep 13, 2012 | 10:01 PM
dh1978's Avatar
dh1978
thanks, i will give it a try.
Old Sep 13, 2012 | 10:18 PM
buttwheat's Avatar
buttwheat
There are three positions front seated, back seated and cracked. They are called king valves you can google king valve to see the positions.
rfxj3
Sep 13, 2010 12:50 PM
70_RangerXLT
Jul 21, 2010 02:33 PM
justme764
Jun 26, 2008 03:37 PM
Woodsman_30350
Paint & Bodywork
Jun 23, 2008 12:03 AM
sarkis
Aerostar
Oct 28, 2003 05:29 PM
