FE engine problems
Old Sep 13, 2012 | 08:11 AM
yepitsadam's Avatar
yepitsadam
FE engine problems
My 390 is burning oil, and the oil and water are mixing both ways. In other words, I have oil in my water and water in my oil.
Before I knew about the oil and water mixing, I could only see that it was blowing blue smoke out of the passenger side exhaust, so I replaced the valve seals. When that didn't fix it, I replaced the intake gasket and made sure the intake was sitting flush when I re-installed it, and that didn't fix it. That's when I discovered the oil and water mixing.
I'm thinking cracked head, bad head gasket, rough block surface, or all of the above. I figured a few more opinions couldn't hurt.... Do you guys have any thoughts?
Old Sep 13, 2012 | 08:46 AM
MIKES 68 F100's Avatar
MIKES 68 F100
SADLY i think your last thought is right , pull some plugs and see what they look like
Old Sep 13, 2012 | 09:34 PM
jshanematthews's Avatar
jshanematthews
Sounds like head gasket to me did you run it hot
Old Sep 13, 2012 | 10:01 PM
MavSprint's Avatar
MavSprint
If you didn't notice the oil in water and water in oil till after the intake gasket was changed that MIGHT be where the leak is. I'd do a compression check along with the spark plug check.
Old Sep 13, 2012 | 11:19 PM
yepitsadam's Avatar
yepitsadam
We were draining the fluids to start changing the intake gasket when we found the oil and water mixed.
It has been smoking blue since my brother got it from a guy who found it sitting in the weeds. I really don't know much about the history of this truck, but she runs great! I wouldn't even worry so much about blowing blue smoke except for the fact that I live in Louisville Metro.
When I first noticed it smoking, I pulled the plugs thinking I might see one black one, but all 8 look the same, so I don't think the oil is actually getting burned. If I have to take the block out, I'm going back in with a 302...
waltharper
Jun 9, 2012 03:23 PM
69reallyhighboy
Jun 25, 2010 11:22 PM
ErrorS
May 24, 2010 08:25 PM
79 f-150 guy
1997 - 2003 F150
Mar 14, 2010 06:49 PM
crossthread
Jan 27, 2003 05:47 PM
