Water in Oil
Old Feb 5, 2012 | 09:36 AM
waltharper's Avatar
waltharper
Water in Oil
I have a 62 f-100 with a 223 inline. yesterday I had one of the speedy oil changes done. They told me I had some water in the oil and it drained off first. I am thinking that I will keep a closer eye on it for a week and then "I" will drain the oil again into a very clean pan and do an inspection of the oil. I know my way around my engine but this one has me wondering on what is going on.
Any suggestions on what is causing it?
I will answer some questions first:
  1. Not missing any water and no oil in the water.
  2. runs ok, does not over heat
  3. some carbon in the exhaust pipe.
  4. No indication of any problems.
  5. I have been using w30
  6. I use about a quart of oil every 1500 to 2000 miles.
I only have speedy do it cause I don't have to get rid of the oil and I don't have a garage.
Old Feb 5, 2012 | 10:47 AM
Shorty 66's Avatar
Shorty 66
Pull the spark plugs and see if any have changed color or are rusty, also do a compression check on all cylinders.
Old Feb 5, 2012 | 12:06 PM
waltharper's Avatar
waltharper
If I had a head gasket leak would that not blow all the water out of the radiatior first before water would get into the crankcase.
Old Feb 5, 2012 | 02:59 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
No. If any of your plugs are perfectly clean, that cyl is "normally" where your problem is, as it steam cleans them. But head gasket could be leaking to the oil passage and not combustion chamber. Another possibility is if you only run short trips, condensation could be built up in the engine. Trips over about 25 miles normally burns this off. Hope that is your problem, but check it out further.
Old Feb 5, 2012 | 03:05 PM
waltharper's Avatar
waltharper
I have a 20 mile one way run to work and then back at speeds at 50mph.
That should keep the condensate down. I will check the plugs this afternoon. and let you know how it is.
If I do change out the head gasket, what else should I do while I have it off. I do not know how many miles is on the old girl. the odometer says 65K but at 50 years old I don't know. I have had her only 2 years.
Old Feb 5, 2012 | 05:15 PM
bunchoftrucks's Avatar
bunchoftrucks
I think you answered your own question with your # 1 answer, if your not down any coolant then there isn't a head gasket/cracked block issue, my opinion. Besides didn't speedy say it was "water" and not antifreeze ? Like you said driving 20 miles each way would burn off any condensation. Reading the plugs is a very good way to identify the problem area.
Old Jun 8, 2012 | 10:12 AM
waltharper's Avatar
waltharper
well, I have been driving the truck for 4 months since the "shop" told me I had water in my oil.
Well 3500 miles later and a new oil change. funny no water.
I am tempted to go back to the "shop" and kick up a little dust.
I have not had any problems and no water any where.
*********s. made me worry for nothing.
Old Jun 8, 2012 | 12:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the oil looks milky, truck could have a blown head gasket that is only seeping a small amount of water.
There is no coolant recovery reservoir on these trucks (unless someone installed an aftermarket from an autoparts store).
When water gets hot, it expands, flows out the radiator overflow tube, so you're going to be adding water every so often.
What lb. radiator cap does the truck have? The radiator cap was 13 lb. originally. Peeps install 4 lb. caps on old rolling piles of misery to reduce the water pressure.
Old Jun 9, 2012 | 03:23 PM
waltharper's Avatar
waltharper
read the first few entries. Like I said after driving the ole girl for another 3500 miles there is no problem.
rustyoldford
Jul 19, 2016 07:17 PM
coleboy11
1983 - 2012 Ranger & B-Series
13
Mar 1, 2013 12:57 PM
yepitsadam
Sep 13, 2012 11:19 PM
Race4Fun82
Mar 5, 2012 05:41 AM
ErrorS
Oct 29, 2009 03:31 PM
