Bronco II Ford Bronco II
235s 75r 15s
Old May 15, 2003 | 09:55 PM
ptodave's Avatar
ptodave
235s 75r 15s
Hey will this size tire fit on an 1984 B2 with no lift? Do I need to be concerned about backspacing on wheels? Thanks,PTO. (15x7 wheels)
Old May 15, 2003 | 11:05 PM
Bronco2guy's Avatar
Bronco2guy
235s 75r 15s
Yes that size will actually fit quite nicely on your b2 with no lift. I have even heard of ppl putting 31x10.50 on stock b2's with only mild rubbing. Anyway, what is "backspacing"?
Old May 16, 2003 | 02:42 AM
pat67shorty's Avatar
pat67shorty
235s 75r 15s
Back spacing is the distance between the back of the rim and the back side of the lug mounting area of the wheel. 30x9.50x15's fit on stock wheels with no rubbing.
Old May 16, 2003 | 09:21 PM
b2_tim's Avatar
b2_tim
235s 75r 15s
You shouldn't have a problem with 235 75 15 tires. I have BFG T/A ko's of that size and on the front at full lock they just rub the sway bar a little when Im in the woods making tight turns. Havn't had them bottom out on the frame or fenders, and I have tried . Put em on and enjoy.
Old May 17, 2003 | 08:51 AM
ShadowBronco2's Avatar
ShadowBronco2
235s 75r 15s
I'm runnin 235 75 15's on my 85 B2 XLT and i havent had any rubbing of any sort yet. If you do find they rub all you need to do is cut the inner fender where the tire hits and that should fix the problem.
