Help! Early morning problem
Old Sep 13, 2012 | 06:46 AM
Powerstroke-7.3's Avatar
Powerstroke-7.3
This morning on my way to work my truck ran just fine as normal. When I got to work I put my truck in reverse to back into my spot and out of no where it started running like s**t almost like a miss. The same thing happens when I put it in first gear as well but runs perfect in drive or even second. The truck is an automatic 4x4.
Old Sep 13, 2012 | 07:11 AM
Powerstroke-7.3
I just went outside and put it in reverse and its not a miss but it bogs down like it was a 5.speed and letting out the clutch and almost stalling.
Old Sep 13, 2012 | 07:17 AM
fordpride's Avatar
fordpride
Is the OD light blinking ?
Old Sep 13, 2012 | 07:27 AM
Powerstroke-7.3
No it is not and I can still turn it on and off.
Old Sep 13, 2012 | 08:02 AM
Supercab's Avatar
Supercab
My vote is for the Under Valve Cover harness (UVCH)......
Old Sep 13, 2012 | 08:23 AM
MTalley's Avatar
MTalley
Sounds tranny related to me. Only reverse and 1st (manually selected) seem to make it run funky.
Fluid pink? Level? Miles on tranny?
Old Sep 13, 2012 | 08:40 AM
Powerstroke-7.3
Fluid level is good and pink, not sure on the miles because it was rebuilt about 3 years ago. I can hear a weird sound from underneath even when in drive but havent tracked it down yet. I also noticed when its in reverse it doesn't bog down right away it may take 30 seconds or so.
Old Sep 13, 2012 | 08:41 AM
snakedoc's Avatar
snakedoc
sound like the torquer converter is locking in revers?
Old Sep 13, 2012 | 08:58 AM
Mitch1407's Avatar
Mitch1407
My vote is to remove the chip... possibly something jarred it loose and youre having a bad connection. Not knocking the chip at all, just mine hit and missed with the chip and it wasnt fully seated... Plus that way you know the trans tunes dont have anything to do with it.
Old Sep 13, 2012 | 09:05 AM
MTalley's Avatar
MTalley
Mitch has a good point. Might move back to stock and see what happens.
Old Sep 13, 2012 | 11:52 AM
Powerstroke-7.3
Cool
Taking the chip out didn't do anything. The truck is stalling in reverse almost everytime now. The only I can back up now is to switch the chip to high idle.
Old Sep 13, 2012 | 12:01 PM
4inchlovin's Avatar
4inchlovin
Do you have any way to scan for codes. sometimes tranny codes wont throw an SES light
Old Sep 13, 2012 | 12:05 PM
Powerstroke-7.3
I wont be able to till late tonight
Old Sep 13, 2012 | 12:19 PM
Mitch1407's Avatar
Mitch1407
Did a google search... stalls in reverse - Diesel Forum - TheDieselStop.com Copy and paste that and see if you can find chaffing on the wires. hopefully just grounding out to the chassis. EDIT: Its the last post on the page...
Old Sep 13, 2012 | 12:26 PM
Mitch1407's Avatar
Mitch1407
TSB
Article No.
97-24-23
11/24/97
^ STALL - ENGINE STALL DURING TRANSMISSION
ENGAGEMENT - VEHICLES EQUIPPED WITH E4OD
TRANSMISSION
^ TRANSMISSION - E4OD - ENGINE STALL DURING
ENGAGEMENT
LIGHT TRUCK:
1996 BRONCO
1996-97 ECONOLINE, F-150-350 SERIES, F-53 MOTORHOME
1997 EXPEDITION
1998 NAVIGATOR
This TSB article is being republished in its entirety to revise the Service Procedure.
ISSUE:
Some vehicles may stall when the transmission is placed into gear. This may be caused by the transmission fluid filter becoming detached and/or loose.
SERVICE PROCEDURE
Follow all the normal diagnostic procedures outlined in the appropriate model/year Service Manual. Repair as required. If all normal diagnostics fail to correct the problem, refer to the following Steps.
1. Remove the transmission fluid pan to determine if the transmission fluid filter has dropped down or is not firmly seated in the pump bore.
2. If the filter has dropped down into the pan, discard the filter assembly and remove the filter seal from the pump bore.
CAUTION : BE CAREFUL NOT TO SCRATCH OR DAMAGE THE PUMP BORE WHEN REMOVING THE SEAL.
NOTE : DO NOT REMOVE THE ORIGINAL FLUID PAN MAGNET FROM THE FLUID PAN OTHER THAN TO CLEAN AND REINSTALL.
3. Install a new Filter and Seal Assembly (F6TZ-7A098-AB: 4X2, F6TZ-7A098-BB: 4X4). Refer to Figure 1.
Got that from another site, but I think you mentioned it...
