Cracking open the fuse panel
of a wiring diagram for the back of the fuse panel I ended up just pulling mine out. I didnt want to tap a fuse for something I was going to keep I'm my truck and wanted to wire it up behind the panel. This isn't 100% but I got most of them in my short time befor work. This is the best way I could see doing this. I have a 2002 Limited 7.3L 2wd.This is a pic of the sticker that is on the side of my fuse panel
[IMG]<a href="http://s26.photobucket.com/albums/c104/cameeks/Excursion/?action=view&current=20120912_022646.jpg" target="_blank"><img src="http://i26.photobucket.com/albums/c104/cameeks/Excursion/20120912_022646.jpg" border="0" alt="Fuse Panel Label"></a>[/IMG]
Here are some diffrent views of it
Last edited by Stewart_H; Mar 31, 2013 at 11:33 PM. Reason: Edited per request of the OP
Here is a drawing of the front and back views.
C270a
1 - R306
2 - F32
3 - F34
4 - F31
5 - F28
6 - Blank
7 - F19
8 - F45
9 - R304
10 - F33
11 - R301
12 - R301
13 - Fog Light Relay on Circuit Board
14 - R306
15 - F41
16 - F29
17 - Fog Light Relay on Circuit Board
18 - F26
19 - Horn Relay on Circuit Board
20 - F24
21 - F27
22 - Fuel Pump Relay on Circuit Board
23 - F42
24 - F16
C270b
1 - F35
2 - Tow Relay Between R302 & R305
3 - F44
4 - R210 (not used)
5 - F18
6 - F20 (not used)
7 - F7
8 - R212 (not used)
9 - F17
10 - F30
11 - F31 & F32 (power supply)
12 - F30
C270c
1 - F103
2 - F110
3 - R304 & R305
4 - F33 & F48 (power supply)
5 - R304 & R305
6 - R302
C270d
1 - F2
2 - Blank
3 - F1
4 - F108
5 - F11
6 - F601
7 - F12
8 - F9
C270e
1 - F101
2 - F4
3 - F102
4 - F116
C270f
1 - Tow Relay Between R302 & R305
2 - F47
3 - F46
4 - F25
5 - R307
6 - R307
7 - R306
8 - Blank
9 - Blank
10 - Goes Through Fuel Pump Relay On circuit board to R210
11 - Positive Side of Diode on Circuit Board and goes to Pin 12
12 - Goes to Pin 11
C270g
1 - R211 (not used)
2 - R307
3 - Blank
4 - F46 & F47
5 - F34
6 - R301
7 - F36
8 - R303
C270h
1 - F30
2 - Fog Light Relay on Circuit Board
3 - Tow Relay Between R302 & R305
4 - R303
5 - F22
6 - F23
7 - F30
8 - F31
10 - Fuel Pump Relay on Circuit Board
11 - F10
12 - F14
C270j
1 - F15
2 - Blank
3 - F13
4 - F23
5 - F16
6 - R212 (not used)
7 - Tow Relay Between R302 & R305 on Circuit Board
8 - R210 (not used)
9 - F48
10 - Tow Relay Between R302 & R305 on Circuit Board
11 - F42
12 - Tow Relay Between R302 & R305 on Circuit Board
13 - Blank
14 - F27
15 - Tow Relay Between R303 & R306 on Circuit Board
16 - R306
C270k
1 - F6
2 - F5
3 - F8
4 - R305
5 - F8
6 - F109
7 - F3
8 - F108
C270l
1 - F21
2 - R212 (not used)
3 - R210 (not used)
4 - F601
5 - F112
6 - F114
C270m
1 - Blank
2 - F111
3 - F602
4 - Blank
5 - Blank
6 - F106
Fuse #37 goes to the Horn Relay on the Circuit Board
Fuse #38 goes to both Tow Relays on the Circuit Board
Fuse #40 goes to the Fuel Pump Relay on the Circuit Board
Fuse #43 goes to the Fog Light Relay on the Circuit Board
Fuse #104 goes to R304
Fuse #105 goes to R303
Fuse #107 goes to R301
Fuse #113 goes to R307
Fuse #115 goes to R305
