LOWERING a 1981 Shortbox Stepside
Old 01-01-2005, 02:10 PM
GreenFlareside's Avatar
GreenFlareside
GreenFlareside is offline
Hello,
I recently ran in to a problem and would like to know about Overslinging the rear Diff but have heard that it is eaiser to Buy a rear frame kit to "NOTCH" the frame so there is no clearence issues. Any help would be of value
Thanks
A.J.
Old 01-02-2005, 01:17 PM
hermangarza's Avatar
hermangarza
hermangarza is offline
????? what dp you mean?
Old 01-02-2005, 02:47 PM
GreenFlareside
Eaisest way put is What is the best way to lower the *** end of the truck.
I was thinking of overslinging the diff and putting air shocks on it.
Old 01-03-2005, 11:57 AM
hermangarza
how would u lower the front?
Old 01-03-2005, 12:11 PM
GreenFlareside
Talking Front end DROP
I have the set from Lowriders Unlimited Code: DB3006-3 Price: $509.95 description is as follows, a pair of front lowering i-beams that fit 1980-1981 Ford F100/F150,These beams are a 3" drop and come with all required parts to complete the front installation.
This is the eaisest way possible....Thanks for asking
A.J.
Old 09-03-2012, 05:37 PM
vette59jdwl's Avatar
vette59jdwl
vette59jdwl is offline
i am having the same delema with the same truck and year .What i am toying with is a 1989 caprice complete frame.The wheel base is out only 1/2 inch not sure about the tracking or if i will incorporate the 81 FORD frame into the Chevrolette caprice frame just an idea.That way i will not have to cut the frame just graft the ford to the chevy just an idea
Old 09-03-2012, 08:53 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,719 Likes on 1,390 Posts
Have you looked into installing the late model crown vic front crossmember into your truck to lower the front?
The rear of these trucks is standard parallel leafs, and the common methods of lowering them apply. Flipping the axle would probably be the easiest, and I would try it without notching first, and only notch it later if you have interference.
Old 09-03-2012, 08:56 PM
BikeMaker's Avatar
BikeMaker
BikeMaker is offline
I had an 82 stepside that I lowered clear back in high school.
DJM 3" drop beams in the front. But it already sat about 1" lower than stock due to a 460 transplant.
First rendition I torched the old spring hangers off of the rear suspension and bolted up DJM 4" drop pieces. Still was pretty high compared to the front so I put the stock hangers on it and flipped the axle over to the top of the rear leaf springs. Used some brackets I also got from DJM to use the existing leaf spring pads on the axle. Sat about 7" lower than stock. I ran 235/75/15 tires in front and 275/75/15 tires in the rear, it sat really nice.
Here's the part you're asking about the rear axle flip; after it was flipped, I chopped the bump stops about in half and was only left with about 2" of upward travel in the rear suspension. Worked OK with 2 people in it, but if you put any kind of load in the bed, the rear suspension would bottom out on a regular basis.
So the correct way to lower one when flipping the axle to the top of the leaf springs would be to notch the frame rails - but it is still driveable without notching them, as long as you don't use it like a truck.
FWIW, that truck sat really nice, still rode just as smooth as stock, and handled WAY better - even without sway bars. I kick myself every day for getting rid of it....
Old 09-09-2012, 07:08 PM
vette59jdwl
lowering a 1981 shortbox stepside
Franklin2. I thought of that so put the word out I CANT FIND ONE OF THOSE ANYWHERE AROUND HERE Kingston East Ontario CANADA as a mater of fact they want more than you guys are paying for the whole front end for just the front crossmember the word must be out lol lol I worked on a tilt caddy telescoping steering wheel and got the ford piece on it for the firwall now all i have to do is switch the wiring
Old 09-12-2012, 02:33 PM
vette59jdwl
Well I went out and tore the front end off of the caprice,then measured everything up the length of the F100 shor-box stepside is 116-1/2 inches.The 89 caprice is 116 inches actuall 115.9 inches the Caprice front end is 61.7 inches center to center of tires the caprice wagon is 64.1.The f100 1981 is 64 center to center i am going to mock this up and see what comes of it
Yazied Rawashdeh
1978 - 1996 Big Bronco
06-22-2016 02:04 PM
bernette
1947 and Older Ford Trucks
11-29-2015 07:46 PM
Aaron-71
08-20-2015 09:42 PM
bulletsneverlie
02-28-2010 06:23 PM
Kookadala
1999 to 2016 Super Duty
03-15-2007 02:39 PM
Quick Reply: LOWERING a 1981 Shortbox Stepside
