Offroad & 4x4
which tree saver to get?
Old Sep 11, 2012 | 04:19 PM
snakedoc's Avatar
snakedoc
i have just gotten a warn M12000 winch for my 1999 f-250 truck which tree saver to get? i do not have a pulley block but may get one some day so i need a tree saver that will work for it. most dont go over 26000 lbs that is close to 24000 not much safety factor for bad angels or other things that will weaken the strap. i would like one made in the USA and longer then 20" so i could use it to extend the line if needed. i dont do a lot of mudding but would like something that will work right and not hurt someone.
Old Sep 11, 2012 | 04:49 PM
tjc transport's Avatar
tjc transport
i ain't rite
tree saver?? whenever i need a wench, there are never any trees around
Old Sep 11, 2012 | 07:50 PM
snakedoc's Avatar
snakedoc
im in AL all there is are trees.
Old Sep 11, 2012 | 08:53 PM
alpha/omega's Avatar
alpha/omega
Forget about the commercially available "tree savers." They are very overpriced and not strong enough for a 12k winch doubled with a ****** block.
Look for a lift sling in a 3-4" width about 6-8' long. Id imagine Grainger or Mcmaster Carr would have them or if you know anyone that works with cranes you would be surprised in what osha makes us throw away
Old Sep 11, 2012 | 08:55 PM
smokenchoken's Avatar
smokenchoken
or just buy a good pull rope they are easier to find and won't damage the precious "tree's" lol
Old Sep 11, 2012 | 09:01 PM
alpha/omega
Find a rope to hold 24k+....
Old Sep 11, 2012 | 09:11 PM
smokenchoken
Old Sep 11, 2012 | 09:31 PM
alpha/omega
A tree saver is not 30' long, usually 6-8', and that's easily 3 times what a 3"x 6' strap would cost
Old Sep 11, 2012 | 10:43 PM
snakedoc's Avatar
snakedoc
from what i have seen you are not to use a recovery rope with a winch it has to much kinetic energy if it where to break.
6" is not much a lot of trees that is about all it would do to go around it.
the trees getting hurt are not my concern breaking a chain and killing someone is.
i have tried to get a lifting strap but they have to cut the up now so they dont get sued.
Old Sep 12, 2012 | 08:47 AM
alpha/omega
A 6' strap will get around a 22" tree and a 8' strap will fit around a 30" tree. Thats pretty damn big no matter where you live.
A "tree saver" is a strap. Its commercially sold by numerous 4wd suppliers. I could a shat less about a tree also. The reason id use one is to save your winch cable.
If you put a towel or t-shirt/coat on the cable it will hit the dirt the second it pops.
Old Sep 12, 2012 | 09:05 AM
Rogue427's Avatar
Rogue427
Check out Buba Rope. They had a add in summit racing. I looked at there web site. Tree savers are cheap and you can double or triple them up. I also use a 4" or 6" strap with my winch. Both are rated several times my 12,000# Warn. I broke a 3" a long time ago after many years of hard use. So I replaced it with a 4" Take a look at the buba stuff and tells us what you thnk.
I'm thinking about getting a spare strap or rope because my kid has a truck now.
Old Sep 13, 2012 | 08:52 AM
alpha/omega
Ive got a Keeper brand 4"x30' and a 6"x30' ****** strap and also a rope thats about 1.25-1.5" diameter and maybe 20' long now. The rope stretches quite a bit and works better when it doesnt pop. Ive never had trouble with the 6" strap but im on my second or third 4" strap in the past 10 years.
Old Sep 13, 2012 | 08:54 AM
alpha/omega
But back to the point of this thread...
I wouldnt use either strap as a tree saver in a winch situation because they are too long and i wouldnt use the rope because it stretches too much.
Old Sep 15, 2012 | 08:22 PM
snakedoc's Avatar
snakedoc
looks like im going with the bubbas tree huger 16'
thanks Matt
Old Sep 17, 2012 | 01:01 PM
quigley513's Avatar
quigley513
4" x 30' yellow poly strap with loops at both ends. Anything else is a waste of money. 3/4" D Shackle both end to the winch line, or, if you have a friend, wrap the 4" strap around the tree three revolutions and have him hold the end. Then it can be undone and attached to another tree without removing the D Shackle.
turbogus
Bronco II
May 12, 2011 04:29 PM
Robert6401
Offroad & 4x4
Aug 23, 2009 01:06 AM
powerstroker27
Dec 13, 2007 12:53 PM
smooth
Nov 13, 2006 05:55 PM
rmroost
Offroad & 4x4
May 19, 2004 10:54 AM
