Engine coolant temp too low?
Old Sep 11, 2012 | 02:42 PM
Austin J.'s Avatar
Austin J.
I have a 96' F-150 4x4 302 Auto and the truck is reading the coolant temp when the engine is hot at 199 degrees. That seemed low to me, and if it is could there be a sensor messed up? I read on a different thread a while back about that affecting mpgs because it thinks the engine is cool and therefore gives it more fuel. If so, how do I fix it, and if that is an okay coolant temp then thank you for telling me.
Old Sep 11, 2012 | 03:02 PM
White 97 xlt's Avatar
White 97 xlt
That sounds about right if you are running a 195° thermostat, as you should be according to Ford...
Old Sep 11, 2012 | 03:06 PM
Austin J.'s Avatar
Austin J.
Okay, just seemed low for an engine, but I guess the coolant does get masses of air on it through the radiator. Probably should have thought about that and the thermostat thing before posting here, but thanks for the quick reply.
RZAR
6.2L V8
Aug 31, 2012 06:32 PM
billbot
Jul 8, 2012 08:48 PM
brooksbronco17
24
Mar 28, 2010 06:00 PM
me Mickey C
13
Feb 10, 2008 12:32 AM
jcstratt
1997 - 2003 F150
Oct 13, 2005 11:45 PM
