Van problem
Old Sep 11, 2012 | 02:38 PM
IanMacFarlane's Avatar
IanMacFarlane
Van problem
I have a problem with my 2005 ford econoline e350 van
After I start the engine and go to begin driving
It the engine revs but the van does not move and then it kicks in
I thought it might be low transmission fluid but the fluid is fine
Is it transmission and if so what do I do or could it be something else
Thanks so mich for the help
Ian
Old Sep 11, 2012 | 02:56 PM
okgearhead's Avatar
okgearhead
It sounds like a transmission problem, could be the burnt clutches in the tranny , causing it to slip ,or the front pump's gone bad ?
Old Sep 11, 2012 | 03:09 PM
IanMacFarlane
Thanks I just went out and tried it and it gradually engages not jerk into gear
Does this help at all with diagnosis
Thanks
Old Sep 11, 2012 | 04:14 PM
critterf1's Avatar
critterf1
Time for a tranny.
Old Sep 12, 2012 | 12:05 PM
Cobra-Kai's Avatar
Cobra-Kai
Did you check the fluid level with running engine?
Some people like to forget that the engine has to run and idling in position "P" or "N"
Old Sep 12, 2012 | 01:02 PM
95e150CW's Avatar
95e150CW
Is the transmission shifter stick blinking OD On/Off?
Old Sep 12, 2012 | 03:28 PM
IanMacFarlane
No it's was not blinking
Thanks guys
I bit the bullet and took it to mr transmission
All the best
Ian
Old Sep 12, 2012 | 03:29 PM
95e150CW's Avatar
95e150CW
If they tell you a number larger than, say, 1800, you can get a complete reman for that and still hve 300 left to pay someone to install it.
daveyboi
Aerostar
Apr 23, 2013 07:39 PM
daredevil95
Modular V8 (4.6L, 5.4L)
Sep 27, 2012 07:16 AM
RustyNutz45
May 2, 2003 07:47 AM
Mark156701
Sep 23, 2002 05:51 PM
