What causes this?
Old May 15, 2003 | 07:23 PM
cocot's Avatar
cocot
Question What causes this?
Why is there this buildup of crud?
Old May 15, 2003 | 07:49 PM
steve83's Avatar
steve83
What causes this?
The inside back cover of the Haynes manual has color pics of spark plugs for diagnosis. If you get one, you'll see YOUR spark plug in the 4th pic down on the L side. It says the ash buildup comes from burning oil & fuel additives. It recommends changing fuel brand & valve guides .
Old May 15, 2003 | 11:22 PM
MEPR's Avatar
MEPR
What causes this?
thats ash deposits, try a cheaper easy way first. Try just richening your mixture a bit. Becouse it looks like you could have a lean running problem too. If that dosnt fix it then im afraid it could be the valve guids as stated.
Old May 15, 2003 | 11:32 PM
Ford_Six's Avatar
Ford_Six
What causes this?
That's oil, as near as I can tell. Might be blow-by getting sucked in by the pcv valve. EFI engines normally run lean like that, so I wouldn't worry about that. Since only one plug has that buildup on it, I don't think it is fuel additives. Pull yor pcv valve off with the engine running, and see if anything comes out. If just a little whiff of smoke is coming out, that's ok. But if it's puffing away, it could be rebuild time.
