dana 44 closed knuckle spindle arm bearings?
i cant speak to the 67 bronze bushings. i ordered all the parts last saturday. hopefully everything will be in tomorrow. waiting on the tie-rod ends and brake shoes. we pulled the diff cover after we discovered the water in the hub. this about made me sick!
on the upside we had some time to kill so i taught my son how to weld.
Another cool pic of the boy!
Mark did your parts come? Hows the rebuild going?
I was out in the boondocks when you first started this thread.
Check your spindle to knuckle bolts and treads. When I was running the big tires my spindles pulled loose (pushing the truck to hard maybe) and ended up re-drilling, tapping for the next size up grade 8 bolts.
Good to see you passing on the skills with your helper.
Good luck in your quest
on
thanks for the kind words guys. the parts came in twice Wally. didnt get them all the first time. wish i would have read about the threads pulling out of the knuckle before i put it together. i wont make that mistake again. im gonna switch over to the other build thread i started just in case someone google's dana 44 rebuild. i tried it before i started this project and came up empty so maybe i can help someone out in the future.
r_reed
09-29-2011 07:28 PM
jman92612
12-19-2004 11:56 AM
