Fuel filter/seperator conversion ?'s
Old Sep 10, 2012 | 12:15 PM
NWVintage's Avatar
NWVintage
So first, hello all! I've been trolling around here for a while and have gotten a lot of great advice through my searching but now I have specific questions. I have a 1985 F250 2WD NA 6.9 and fuel delivery has been quite an issue. I replaced the mechanical fuel pump with a Duralift, took out my water separator and will be doing injectors/return lines in the next week or so (no apparent leaks right now but no matter how the timing is set, there's missing and smoke). Also worth noting, there's no coolant in the oil, no oil in the coolant, no coolant usage and no excessive oil usage (some but nothing major).
My questions are these:
  1. Can I use the fuel filter/water separator/fuel heater assembly from a 1989-93 IDI? Or is there a better answer?
  2. What is the purpose of the fat spot in the fuel line with a wire coming out of it on the hard line that goes into the current fuel filter housing?
Thanks guys!
Old Sep 10, 2012 | 12:29 PM
BeerCan500's Avatar
BeerCan500
Thanks guys!
Fat spot is fuel heater....
You can use any filter/water separator you want...I just went and bought a mount and a spin on water/fuel separator and mounted it on the drivers side firewall where the oem one was...
no problems whatsoever...
Old Sep 10, 2012 | 12:44 PM
NWVintage's Avatar
NWVintage
That's what I thought.
Also, kid of what I thought. My hard line with the fuel heater is kind of trashed (a bit kinked in one spot) so I'm thinking of junk-yarding one of the newer housings to get rid of that line and have a one-location fuel filter/separator... I mounted my duralift on the inside of the PS fender - more or less where the mechanical pump was - so I'd also just have one soft line from the pump to the filter housing.
Thanks!!
Old Sep 10, 2012 | 01:01 PM
BeerCan500's Avatar
BeerCan500
Duralift Pump
Thanks!!
Just my opinion...I think I would put the water/fuel separator in line before the Duralift and use a Motorcraft fuel filter at the mount near the alternator...
Old Sep 10, 2012 | 03:23 PM
typefour's Avatar
typefour
I use a detroit diesel primary as a prefilter 30 micron comes in different lengths. bases are available many places.
napa filter 3118,long 3121 short.
Old Sep 10, 2012 | 04:15 PM
NWVintage's Avatar
NWVintage
What would be the advantage to using a separate water separator? All the new ones have them in one unit...
Old Sep 10, 2012 | 05:24 PM
BeerCan500's Avatar
BeerCan500
Advantage
1. to protect fuel pump, the electric ones
2. prefilter the fuel before second filter which should filter fuel to a lower micron size, to help protect IP and helps keep injectors cleaner
Just my thoughts
Dirtboy953b
Nov 30, 2014 07:31 AM
84-250
15
Aug 17, 2011 09:33 PM
thelast50ho
Jun 29, 2009 09:16 PM
Pele
Aug 26, 2007 11:00 PM
firemediceric
20
Apr 17, 2007 01:26 PM
