Sponsored by: Auxito
#4 cylinder coil replacement
Old May 15, 2003 | 04:32 PM
StevePA's Avatar
StevePA
I need to change the coil on cyl #4 and am pretty sure it is the passenger side far back one but wanted to check to make sure. I was told that Ford numbers the cylinders 1-4 on the passenger side and 5-8 on the drivers side. Is this correct? I guess it would look like this
BACK OF TRUCK
4-----8
3-----7
2-----6
1-----5
FRONT OF TRUCK
I hope this posts looking th same way as it does right now.
Thanks!
Old May 15, 2003 | 06:41 PM
StevePA's Avatar
StevePA
I also would like to know EXACTLY how to release the plug that connects to the coil. I did the #2 coil about 1 month ago but that was easy to get to and I just messed with it and eventually it came off. This #4 one is really hard to get to so I need to know what to do to get the plug off without breaking anything. Any other pointers that would be helpful are also welcome. Thanks in advance.
Old May 15, 2003 | 07:46 PM
Racerguy's Avatar
Racerguy
You've got the cylinder numbers right
To release the connector on the coil you just push in the little tab on the bottom side of it and pull on the connector.
You might want to practice on #1 first so you can see how it's done.
To make a bit more room to get at the coil you can move the heater hoses a bit and maybe tie them back.
Also rotate the injector near the coil a bit so it makes a bit more room.
Old May 16, 2003 | 02:20 PM
StevePA's Avatar
StevePA
Thanks Dave! I have to pick up the coil today and I'll try to work on it today. If I don't finish it today it will wait till Sunday. It's nice having an extra vehicle! I just wish it would fit in my garage so I could do it in there since we are suppose to get rain tonight and tommorow.
Thanks Again!
ilateapex
Modular V10 (6.8l)
May 6, 2012 03:20 PM
weldworks54
Sep 3, 2011 08:11 PM
daliam32
Nov 24, 2010 04:43 PM
oddsix
1997 - 2003 F150
Dec 18, 2003 05:49 PM
