Sponsored by: Auxito
fuel problem 1997 f250
Old Sep 9, 2012 | 05:42 PM
beanhead50's Avatar
beanhead50
I have a 1997 f250 2wd 8800lb with dual tanks with the 5.8l. Recently the truck will all of a sudden stop running, always at idle. I switch to the other tank and after 5 secs. of cranking it starts. Switch back to the front tank runs fine. Same thing happens the next day, 3 consecutive days now. Is this something I can fix at home or do I need to get the truck to a shop. Thanks
Old Sep 9, 2012 | 06:12 PM
Bluegrass 7's Avatar
Bluegrass 7
Soneone needs to do diagnostics to find out.
Either you or a shop.
I suspect it's not fuel but electrical if it dies unpredicitable and sudden.
Crank sensor plug, fuse seating, PCM relay, anything until it's run down.
Good luck.
trollin91x250
Mar 22, 2013 07:09 PM
metalmilitia212000
Nov 3, 2011 05:17 PM
shopkins1994
Mar 24, 2010 08:40 AM
ELKMCC
Aug 5, 2002 12:24 AM
JDsnowmobiler
Apr 3, 2002 10:20 AM
