Leak found by mistake
Old Sep 8, 2012 | 06:29 PM
sand_fiend's Avatar
sand_fiend
My front end has been popping for some time now. I got under the truck to tighten the U-bolts which took care of the popping and i happened to look up..
My truck has been using a little water over the last year or so. I have to put in about a quart of water/antifreeze about every three months or so. I have looked before and never saw any sign of a leak. it dose not drip sitting or after a long drive. But now i see fresh rust on the crank pulley and the under side of the water pump.
I need a write-up on changing the water pump please.
How hard is it on these trucks ?
Should i get an OEM waterpump
I could use my book but i like the detailed instructions you get on this site better..
http://i302.photobucket.com/albums/n...d/P9080121.jpg
Old Sep 8, 2012 | 08:40 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Cheak the video out in this thread.
https://www.ford-trucks.com/forums/1...pump-leak.html
Water Pump, Got mine from Clay.
Riffraff Diesel: OEM Powerstroke Water Pump
Old Sep 9, 2012 | 11:06 AM
sand_fiend's Avatar
sand_fiend
That doesn't look too hard on these trucks. for some reason, I thought there was way more in the way to pull off.
I have been wanting to do the antifreeze flush, thermostat and the duel alternator upper hose for some time now. I guess there was a reason i had not done it yet..
I did changer the belt two months ago.
Anyone know where i can find that big wrench for the fan nut ?
Old Sep 9, 2012 | 11:10 AM
Crewcab Turbo's Avatar
Crewcab Turbo
Autozone rents the fan clutch wrench kit. Advance Auto does also.
Old Sep 9, 2012 | 11:16 AM
sand_fiend's Avatar
sand_fiend
Nice.. Thanks...
I'll call clay in the morning and have him send me a Yellow taped box...
Old Sep 9, 2012 | 12:54 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Good luck
If you need any help let me know. I've been around the block with a water pump a few times.
Old Sep 9, 2012 | 01:22 PM
sand_fiend's Avatar
sand_fiend
Originally Posted by A/Ox4
Good luck
Thanks trey.. I'll let you know. I could just drive to ford and buy one, but i want to help out the people on here that help us out..
Old Sep 9, 2012 | 01:36 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Well give Clay a shout. He might not be reachable by phone now, but email should go through. He is moving.
Jollygr33ngiant
Jan 7, 2016 04:23 PM
KH85
Jun 13, 2013 11:25 PM
Cowgirl Caddilac
Jun 7, 2013 09:22 AM
Flying Finn
17
May 15, 2011 05:26 PM
tpinmanf375
Apr 18, 2011 02:16 PM
