I have a 92' bronco e4od. My tranny was jumping in and out of gear (mostly overdrive) so I had my tranny completely rebuilt last summer. Now it's doing it again. what could be wrong? Electronics? Who makes a good replacement for the stock tranny?
I'm getting an MLPS code, although I'm not experiencing symptoms that other people see with a bad MLPS. Was it a cheap/easy replacement, and what symptoms did it correct when you replaced it?
At first, I thought the trans was slipping. Checked the fluid, color, smell - all OK.
Took it to an independent shop that had a heck of a reputation and the tech said no codes. So I told him to ake it home and drive it around. He did so with a monitor attached.
Next day he said it was fine, the MLPS needed to be replaced. It is a glorified neutral start switch that had loosened up. The computer thought it was getting the signal to go from OD to 2nd downshift.
It not only fixed that, but the soft shift qualities and the somewhat loose shift lever.
When I first got my Bronco, I thought the shifts were way too smooth and slow, especially at 3/4 throttle. I have had shift kits in my GM transmissions and also installed adjustable vacuum modulators so I am accustomed to firm shifts. My new Chrysler Concord has a firm shift too, especially for a factory program.
Anyway, not long after I got the Bronco, I found FTE and noticed many comments about the mushy shifts. Seemed either a chip or a shift kit (but not both!) would be the cure.
Then, my trans started to "slip" (OD to 2nd gear, actually). After the new MLPS was installed, there was a most definite and noticeable improvement in shift quality. I think it is still a tad soft, but it firmed up quite a bit.
I have no idea why that would be unless it is something like the MLPS was not giving consistent signals to the computer.
It's just a glorified Neutral Safety Switch on the L side of the transmission where the shift lever is, like always. Make sure the trans is in Neutral before you start working - that's where the alignment mark is.
