Oil
Old Sep 9, 2012 | 08:26 PM
  #31
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I ran royal purple 10W-40 synthetic in my TurboII K-car. When I put another one together (totaled by an ML320) I will run it in that one also.
Old Sep 9, 2012 | 08:31 PM
  #32
smokenchoken's Avatar
smokenchoken
personally i always used castrol 10w-40 in newer engines and 20w-50 on my older motors and change it religiously every 3000 miles
Old Sep 9, 2012 | 08:47 PM
  #33
Opossum's Avatar
Opossum
FWIW I worked in part as a Royal Purple distributor for a rather well thought of company, shoot Josh and Don might know them, Warehouse West in Renton, and even in that positition try as I might I couldn't get them to actually tell me what their oil actually was. Even when their sales rep came by, I got shirts and stickers but no answers. I was trying to find out if they used a refined dino class III base stock or a true synthetic PAO type IV base stock, or a mix. Because of that and other information that leads me to believe that it is type III I will not use or recomend it and say it's over priced snake oil.
Of course the Rotella T6 "Synthetic" I use is also a Type III oil, but a very good and reasonably priced one. Right now I only know of 3 brands that are true type IV based oils, Amsoil, Redline, and Mobil 1
EEEECK This Don is why I make my arguments.
Old Sep 9, 2012 | 09:08 PM
  #34
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by Opossum
Of course you do.
Guys I don't care to argue, take my advice, don't take it, I don't care if your engine doesn't last as long as it could. I just felt like helping others understand. Re-read what he said with several facts in mind; that engine temps are regulated and rather consistant once running, that he makes no mention that the ratings are at different temps and standard, that at 210F there is NO differnce in viscosity between a 0W40 and a 15W40, the number before the W is at 0deg F and the number after is at 210deg F, the effect of friction modifyers and the differences in dino and syntheitc as noted.
It matters at start up when the engine is cold. When the engine is warm, then you are correct. Before the engine is warmed up, the ambient temperature outside is a factor in what oil you run, and at what viscosity.
Sure outside temps matter, most of all at startup and sure if it's really REALLY hot where you live when your starting your engine then yeah a higher W number has a place. And sure if really hot or cold and your engine can't keep it's oil temp stable then a different second number has it's place. But all you have to do is look for yourself to see the truth. Compare the thickness(viscosity) of your oil when you drain it from a hot engine with it's viscosity when you poor in fresh stuff at outside(starting) temps. It's thicker isn't it, ideally your oil never needs to be any thicker then it is when drained hot, even when cold. So the ideal oil is one that is the same viscosity at both temps.
You are confusing viscosity, with thickness and density. Viscosity is not thickness, (a very comon mistake) it's the rate of resistance to friction or flow. I think you will find that the viscosity of multiweight oil is higher when it's hot, than when it's cold by design, even though it's thinner when hot.
But you don't have to take my word for that either...
Understanding Absolute and Kinematic Viscosity
My favorite explanation of viscosity from the above page is the mayonnaise vs. honey viscosity example. Mayonnaise will not flow out of a jar like honey, but which one is thicker, mayo or honey?... Which can you stir easier, mayo or honey?..
The viscosity of multigrade oils increases with temperature, but it also gets "thinner" with heat. Think mayo vs honey again...
So re-read what he just said, and ask yourself if this makes any sence or is he arguing just to argue.
For people who know me, I do not argue. I will speak up if I think you are wrong or mistaken. Your advice may ruin peoples engines, and I will stand by that assessment.
I suppose I'll address a little of what he said, for kicks and clarity.
IDK why so specific on 90, nothing changed in 90 to affect any of this.
It's a date I picked for clarification, nothing more. In the mid 90's Ford started recommending oils in lower viscosities, 5w-30 recommendations are comon begining in '95 for example. There is a reason for this. Better measuring techniques of clearances using computers, and some of the first rollerbearing camshaft engines started rolling off the assymbly line in the '90s. My ex wife's 1997 taurus had such an engine etc... Putting 10w-40 in that taurus would ruin it. I would run 5w-30 in that Taurus all day long. I will not put 5w-30 in my truck unless it gets below 50 degrees. EVER. Because it would ruin my engine in my truck. Two different style engines, with two different build techniques.
The way engines were made changed in the 90's. So did the manufacturers recomendations to go along with it.
For the most part, BUT it doesn't consider everthing and isn't up to date on modern oil tech.
Modern oil tech is the same tech that reduced or eliminated zinc from modern oils, because modern engines with rollerbearing camshafts do not need it, and zinc is a factor in reducing catalitic converter lifespan. The same zinc that is needed on our older engines to keep the camshaft lobes from wearing flat. Newer modern oils are not friendly to our older engines at all. Why I use 15w-40 diesel oil. It's one of the few oils that still has some lubrication traits that our older engines need.
LMAO, ONLY he says, cause that is such a narrow range of temps. The world we live in is never somewhere between -10 and 90 outside, geez.
I'm not the only one who say's that. That is Fords recommendation for temperature range, not mine... but you do not have to take my word for it, look at the manual.
10w-30 Recomended for between -10F and 90F only.
Hey we do agree on something
You will never convince me that putting dirty oil from one engine into another is a good idea. Sorry.
My oil pressure dipped just a little too low when really hot and at a low idle. Sure it's from wear, likely both at the bearings and in the oil pump. Why, idk, I got it in 2007, it was already 20 years old, I have no idea the actual milage and not all that well taken care of at that point. I have no idea what previous owners had put in it. Maybe 15W40, the guy I got it from did mostly have diesels, I have no way of knowing. What I do know is it's worn pretty bad, had so much blowby when I bought it that it blew about 3qts all over the traffic behind me during the 15 mile trip home . And when I got it really hot with 5W30 in it the oil pressure was too low at my nice low in gear idle. Well sure, but in the real world with real oil that you can really buy this doesn't really happen. 90s wow 115k would be low miles, no it's a 2001 Maxima. And before you start, 5W30 is the manufacture recomended oil.
It's a car built after 1990 as well. I wouldn't use a 10w30 in that car anymore than I would use a 5w-30 in my truck.
10W30 if warm enough and ya want. But no reason to do that unless using dino oil and want to go a while between changes, neither of which I do. For most of it's life it's had Mobil 1 5W30 in it, but when I found their 0W30 for the same cost I switched to it. It also has redline synthetic ATF in it and other then a small mod to the front axle/wheel/brakes for safety is stock and been 100% trouble free except for the axle thing and a wiring harness plug that liked to come just loose enough to throw a code. I left out MANY factors, this is a post on a forum not a research paper on oil.
No, the purpose of the forum is to put out reliable information to help other people in need.
I have nothing against you personally, just your advice needs more thought and research as it's inaccurate in several ways.
Old Sep 9, 2012 | 09:25 PM
  #35
Opossum's Avatar
Opossum
Originally Posted by 81-F-150-Explorer
... your advice needs more thought and research as it's inaccurate in several ways.
There is nothing inaccurate about anything I have said here short of an exact comparision between viscosity and thickness, there I used simple common but not completely 100% accurate terms. It's not like 99% of people use the term viscosity in that manor or anything.
Old Sep 9, 2012 | 10:05 PM
  #36
81-F-150-Explorer
When you talk about or give advise about oil, you need to know the difference between newtonian and non-newtonian based oil as they react differently to flow, verses viscosity.
When you said...
... you were incorrect. Multigrade oils behave in a non-newtonian fashion. Even though the oil is thicker when it's cold, and thinner when it's hot, it's got the exact opposite viscosity properties, or exactly opposite of your statement above.
Single grade like SAE 30 behaves in a newtonian fashion, and would therfore behave like you stated above.
Old Sep 9, 2012 | 10:41 PM
  #37
Opossum's Avatar
Opossum
.... difference between newtonian and non-newtonian based oil as they react differently to flow, verses viscosity... you were incorrect. Multigrade oils behave in a non-newtonian fashion..... opposite viscosity properties, .... newtonian fashion.....
Now clearly your just arguing to argue.
Buddy your reading way too much into some article you found on the net, assuming much more then it implies, and being WAAAAYYYY to picky about exact terminalogy that your not even using correctly. ALL motor oils demonstrate non-newtonian properties, this does not make them "non-newtonian based oils" Nor does a non-newtonian fluid behave consistently as you seam to think, some flow rather well, some don't, some stir well, some don't. Non-newtonian simply refers to NOT-newtonian, as in NOT applying to the simple fluid flow models devised by Newton, few real world fluids are truely newtonian, incuding "single grade" oils and honey. Any fluid being non-newtonian is more a matter of degree then anything else, and really the term has more more to do with tricks sean on TV and YouTube then real fluid dynamics. In fact being non-newtonian is part of what makes a good oil.
The same can be said about the term "viscosity" there's how it's used in oil commercials and how it's used in the lab where often modified by another defining term like the ones I already mentioned; kinematic, centipoise, centistoke, shear, etc.
But does it really matter, nope, you go to the store, and you have a selection of motor oils to choose from. Your not engineering your own oil everytime you change it.
http://www.youtube.com/watch?v=3zoTKXXNQIU
Old Sep 9, 2012 | 10:56 PM
  #38
Stangrcr1's Avatar
Stangrcr1
I was going to say something...
Old Sep 9, 2012 | 11:10 PM
  #39
LARIAT 85's Avatar
LARIAT 85
10w-30 Recommended for between -10F and 90F only.
I will agree with 81-F-150-Explorer here. My own 1985 Ford manual states the exact same information.
In the mid 90's Ford started recommending oils in lower viscosities, 5w-30 recommendations are comon begining in '95 for example. There is a reason for this. Better measuring techniques of clearances using computers, and some of the first rollerbearing camshaft engines started rolling off the assymbly line in the '90s...
...Modern oil tech is the same tech that reduced or eliminated zinc from modern oils, because modern engines with rollerbearing camshafts do not need it, and zinc is a factor in reducing catalitic converter lifespan. The same zinc that is needed on our older engines to keep the camshaft lobes from wearing flat. Newer modern oils are not friendly to our older engines at all.
I agreed with this, too. And I just can't bring myself to argue oil weights with a man that has over 700,000 miles on his engine.
On the other hand, I have also heard (and agree) with many of the statements Opossum has brought up in this discussion:
It's much more important that all the oil that can gets in all the places it can get as much and as quickly as possible, most of all at startup. Something like 95% of wear is at startup, ANY small amount of time removed from getting the oil where it needs to be is a VERY good thing. That and with a thicker oil then you need all your doing is creating drag and heat from pumping it around. Yes 40 can be good in a hot loose engine, I use it in my 460 as stated.
BUT it's the 10W that really kills ya, W doesn't stand for weight, it stands for Winter, which is silly, should be C for cold but ohh well I didn't create the standards. It's based on the viscosity of the oil at a cold temp, the other number is at a hot temp 210F. I can't remember the low temp. So the higher the W number the longer it takes to get oil to where it needs to be at startup. So why aren't all oils OW you ask, well that comes from the characteristics of dino oil, regular 30 weight oil if it had a W number would be 30W30 to make a 5W or 10W they add viscosity modifyers to the oil to change it's temperature charactaristics. These additives however are bad for the oils ability to lube and last as a whole so it's a trade off between faster oiling at startup and better oiling when warm and oil longevity. What they do to make a 10W40 is take a 10 weight oil and add enough stuff to it to make it act like a 40 when hot. The downside to this is that these additives break down, so as the oil breaks down it becomes a 10W30 then a 10W20, and eventually just a 10. Ohh and as they break down they become sludge, it's not the oil that actually breaks down it's the additives.
Taken from: http://www.bobistheoilguy.com/motor-oil-101/
"Confusion occurs because people think in terms of the oil thinning when it gets hot. They think this thinning with heat is the problem with motor oil. It would be more correct to think that oil thickens when it cools to room temperature and THIS is the problem. In fact this is the problem. It is said that 90 percent of engine wear occurs at start-up. If we are interested in engine longevity then we should concentrate our attention at reducing engine wear at start-up."
If I am understanding Opossum and the website above correctly, both 5W-30 and 10W-30 oils have the same thickness at operating temperature. The only time the 5W-30 oil is "thinner" than a 10W-30 oil is at cold ("W") start-up conditions where you need it to be "thin." This allows the engine to get quick oil flow when it is started cold verses dry running until lubricant either warms up sufficiently or is finally forced through the engine oil system. The advantages of a lower W viscosity number is obvious. The quicker the oil flows cold, the less dry running. Less dry running means much less engine wear.
Conclusions? The 5W-30 simply does not get as thick on cooling as the 10W-30, thus is better for your engine in colder temperatures and at start-up, where most of the engine wear occurs.
Maybe Opossum and 81-F-150-Explorer are both correct. Were the oil standards somehow different in the 1980s when the Ford manual was produced compared to today's oil standards? This would certainly make sense, as today's oils are better than they were 20 years ago, and additive packages have certainly changed over years as the car engines have changed.
I personally use Motorcraft 5W-30 Synthetic Blend motor oil along with a Motorcraft FL-1A oil filter, as this is what my trusted ASE-certified mechanic told me to use when he rebuilt my engine last year, along with a bottle of ZDDPlus added to the engine oil at every change to protect the flat-tappet camshaft. Maybe that is what Ford tells mechanics to use these days, or maybe it is because he used a high pressure (not high volume) oil pump in my engine. At any rate, my engine seems to run fine with no leaks so far and with quick, high oil pressure at start-up and good oil pressure when hot. I live in South Carolina where temperatures reach close to 100 in the summer with very mild winters, and I only drive my truck 1-2 times a week.
I keep hearing and reading conflicting information on this issue, so I am not confident if I am using the correct engine oil weight for my truck or not. I hope I find out in this thread because I really respect both Opossum's and 81-F-150-Explorer's opinions.
Old Sep 9, 2012 | 11:12 PM
  #40
Opossum's Avatar
Opossum
Originally Posted by Stangrcr1
So are you saying that since Ford recommended a certain oil(10w40 by my original owners manual) for my truck, they are now wrong?
Did I say that, NOPE could there be something better then regular 10W40 for that Ford now, YUP. I don't know, it's your truck, and you haven't told me much about it.
So of the above posts, what is opinion and what is incorrect info, in your OPINION?
Already said that in MY posts above, all you have to do is read them. If that's not enough then clearly you have a computer with an internet connection, go find out for yourself.
But WE were asked by the OP, then I was asked for more from the OP, I answered and then defended my answer. Then YOU asked me, I gave and defended my answer. If you have a problem with that fine, but don't come at me like a moody woman who refuses to find out or think for herself cause I hurt your ego.
Edit, LMAO, I see you edited your post now.
Old Sep 9, 2012 | 11:21 PM
  #41
Stangrcr1's Avatar
Stangrcr1
Well, lets just say this argument has been going on since oil was invented.
Still trying to understand where you missed the part about the differences in oil and engines from 30 years ago til now.
Old Sep 9, 2012 | 11:31 PM
  #42
Opossum's Avatar
Opossum
Good stuff LARIAT 85, can't fault any of it and thanks for the backup/mediation, lol. Sounds like your all set, there might be a better oil, but can't fault it. And the ZDDPlus is a very good thing. My only concern for you I highlighted in red below.
Ya sure it's not the other way around, most engine builders go the other way, as do I. When it really comes down to it an engine doesn't need any more oil pressure then is needed to provide enough flow. So the only thing a high pressure pump does is put in a heavier pressure relief spring and bypass it less. While a high volume pump is actually larger and will ensure oil gets where it needs to go faster and maintain enough volume to maintain a more steady oil pressure.
Old Sep 9, 2012 | 11:39 PM
  #43
Opossum's Avatar
Opossum
I'm sorry isn't this a forum about 30 year old trucks, and can you go back in time and buy oil made 30 years ago?
Old Sep 9, 2012 | 11:40 PM
  #44
Stangrcr1's Avatar
Stangrcr1
There is no real need for a high pressure or high volume pump unless the clearances are wide. Stock pumps should provide all the pressure and volume required.
And here we get to flow through the bearings, etc.
Not enough flow and the bearings heat up. Too much flow and you build backpressure. This backpressure can break the pump and/or the shaft. This also increases the drag internal to the engine and reduced fuel efficiency.
A high volume pump bypasses more oil and heats the oil needlessly.
Old Sep 9, 2012 | 11:42 PM
  #45
Stangrcr1's Avatar
Stangrcr1
I buy the closest thing which is 15w40 refined for my diesel which has the extreme pressure additives.
