I have a 2006 F350 w/ the 6.0L. Im doing the EGR delete on it and im stuck trying to find out how to remove the turbo petistal. all help is needed, im lost
is the turbo still bolted to it? if so remove the turbo from it.
if not tilt it and it will clear the egr tube.
also if the oil return is still installed u need to remove that first
