1966 - 1977 Early Broncos
Rear end question
Old Sep 7, 2012 | 05:10 AM
willowbilly3's Avatar
willowbilly3
Rear end question
I thought all 67-77 Broncos had a 9 inch. I have a friend who claims other wise. Whose right?
Old Sep 7, 2012 | 06:45 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
They all had a nine inch rear, just different bearing size. The front diff changed from a Dana30 to a Dana 44 about 1973, may be what he's thinking about.
Old Dec 11, 2012 | 06:16 PM
monstersmlblk's Avatar
monstersmlblk
9" Rear
Yes they only came w/ 9" rears, and I think the bearing size did change. The original housing ends were called Big Ford Housing Ends, then in 1973 I believe they changed to New Style Ford Housing Ends. They have a different bolt pattern and stick-out dimension, so you need to make sure you have the correct axles and backing plates for your rear.
Old Dec 12, 2012 | 10:30 AM
chrlsful's Avatar
chrlsful
Yes, 9 inch only - 3 different sz axle bearings, the "big b." wuz in later yrs. I believe all the yokes were the same, 2 gear options, and 2 LS type options, Also later yrs trapizodial reinforcement to housing...(correct me if I'm wrong on any of this).
Willowbilly3, what's the issue with it? just a Q or do U need further info for a specific resto/mod/maintenance issue?
DR Smith
Feb 13, 2023 11:48 PM
ChuckRob
18
Jun 2, 2012 10:59 AM
JameyZ28
Jul 24, 2008 10:44 AM
dakuda
Oct 24, 2007 04:27 PM
Mav06
Feb 6, 2007 07:02 AM
