Sponsored by: Auxito
Manual Window Regulator
Old Sep 5, 2012 | 09:55 PM
MavSprint's Avatar
MavSprint
I'm posting this question for my brother who has a '97 Extended Cab F150 2WD auto with manual crank windows. The X-bars that raise and lower the window twist and bind about half way up. Has anyone had this problem and solved it?
Old Sep 6, 2012 | 07:29 PM
Lime1GT's Avatar
Lime1GT
There are guide channels front and rear for the glass to follow down into the door as you lower the window. The rear lower channels fastener bolt can come loose or the channel can separate from the upper door channel and cause glass binding when rolling up. The channels felt strip can also drop down and cause problems. If any channel fasteners are loose/broke the glass can also skip out of the channel and cause binding. There are nylon wheels on the x-frame that may need to be cleaned and re-lubed.
My own truck I bought used, the drivers window would momentarily bind half way up with power windows. I removed the door panel and found someone had been in there for whatever reason. They had removed the rear channel and when reinstalling it they missed the sliding glide clip at the top of the channel. The channel still fastened but left the guides joint off center. Repositioning it correctly solved the binding.
Old Sep 6, 2012 | 07:42 PM
MavSprint's Avatar
MavSprint
Thanks for all the good posibilities. I'll pass them along.
Grizzdaboss
Mar 30, 2016 09:57 AM
cixelsyd
1997 - 2003 F150
Aug 23, 2010 10:42 AM
teerex
Jul 10, 2009 11:57 AM
BLariat
2004 - 2008 F150
Apr 16, 2009 03:14 PM
highlandescape
Escape & Escape Hybrid
Jan 25, 2009 06:51 PM
