MLPS Questions
Old Sep 4, 2012 | 07:14 PM
danlee's Avatar
danlee
MLPS Questions
I'm putting an E4OD/4R100 in my '53 f100. I got a used trans that is supposed to be a '94 E4OD, but I think that it's a '95 or later 4R100.
It had a broken MLPS, so I got a used analog MLPS and installed on my transmission shift lever. Then I measured the resistance from the Light Blue to the Gray wire, while I shift the trans.
Park = 4, 180 Ohms
Reverse = 1, 447 Ohms
Neutral = 734 Ohms
Drive = 401 Ohms
2nd = 401 Ohms
1st = 86.7 Ohms.
Is this MLPS defective?
Is the shift pattern the same on a 4R100 as an E4OD?
I am going to use a Bauman Optishift controller, so I can use the analog MLPS.
Old Sep 4, 2012 | 07:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first 4R100 was in 1999. The easy way to tell if you have and E4OD or a 4R100 is that the 4R100 has two speed sensors on top of the trans, while the E4OD doesn't have any.
No two positions in the MLPS will have the same resistance. Something is wrong there.
Neither the E4OD not the 4R100 have shift patterns. Shift patterns are located in the computer, not in the transmission.
Old Sep 4, 2012 | 08:10 PM
danlee's Avatar
danlee
I have a speed sensor on the top of the extension housing. There is a reluctor wheel on the output shaft. There is no speed sensor on the trans.
The trans has the later solenoid connector.
I meant the shift selector positions. Does the 4R100 have 7 positions, the extra being OD?
Old Sep 4, 2012 | 08:58 PM
Mark Kovalsky
That's an E4OD, not a 4R100.
The E4OD and 4R100 both have 6 positions. P, R, N, OD, 2, 1.
Old Sep 4, 2012 | 09:10 PM
danlee's Avatar
danlee
I'll take the MLPS off my 83 F100. That has a small block with an E4OD. I'll swap that one into the new trans, and check the resistance.
Old Sep 6, 2012 | 07:34 PM
danlee's Avatar
danlee
OK, the MLPS is OK. The resistance readings are:
Park = 4, 180 Ohms
Neutral = 734 Ohms
Drive = 401 Ohms
2nd = 230 Ohms
1st = 86.7 Ohms.
My next question is:
What is the bolt diameter & thread pitch for the transmission mount to transmission bolts? Are they Metric or US threads?
Old Sep 6, 2012 | 07:35 PM
Mark Kovalsky
They are metric. I don't know the size.
Old Sep 6, 2012 | 08:31 PM
danlee's Avatar
danlee
I purchased a couple of Metric bolts today. they are M12 x 1.75. That's a coarse thread. They go in the holes so far, and then bind. I guess That I'll have to try M12 x 1.25.
M12 is almost a 1/2" diameter bolt. I have a couple of 1/2 - 13 bolts. I'll try them also.
George D.
Jun 29, 2010 07:25 PM
dyoung14
Jan 18, 2010 12:04 PM
