Cant Stop!
Old Sep 4, 2012 | 06:22 PM
BillyBob Muirhead's Avatar
BillyBob Muirhead
Cant Stop!
Hey all, I have a 1990 F250 7.5ltr 460. My brakes were a little spongey so I bled them and they stiffened up. this morning on the way to work I couldn't stop without using the emergency brake. All fluid levels are fine. any ideas?
Old Sep 4, 2012 | 06:38 PM
norfolknova's Avatar
norfolknova
What did the pedal do when you couldn't stop. Did it go to the floor? Did it not move at all?
matt
Old Sep 4, 2012 | 06:46 PM
danr1's Avatar
danr1
First thing comes to mind is master is blown 0 ring/s internally. However that's working on assumption pedal goes to floor very little resistance or none, reason had to resort to E brake.
Remove both lines from the master block ports, solid plug them so as no pressure can pass.
Solid pedal?
If not pedal goes to floor? problem very likely in the master itself, replace it following included instructions to the letter to "bench bleed" before installing on truck.
Pedal solid, problem is down stream.
Blown rubber line, budges out but doesn't leak.
Cracked/flexing caliper or rotor cooling fins rotted out, crushed (you'd likely felt that).
Possible problem in the RABS unit.
Old Sep 4, 2012 | 10:04 PM
BillyBob Muirhead
matt
It went all the way to the floor!
Old Sep 4, 2012 | 10:09 PM
BillyBob Muirhead
I will check it! This morning it had no pedal at all so yes that was the reason for e-brake. It is tight prior to starting but once engine is running it goes to the floor with no resistance. the master was replaced about a year ago by the guy i bought the truck from.
Thank You.
fasthauler
28
Sep 30, 2018 10:41 AM
cr506
18
Apr 8, 2010 08:16 PM
ham-n-swiss
Jan 3, 2010 02:29 PM
lottscreek
Nov 7, 2005 08:29 PM
billman
May 3, 2003 11:53 AM
