Brake Pedal Travel
Brake Pedal Travel
Just a quick question:
How many F-150s out there have a lot of brake pedal travel? I have good braking power, but when I put on the brakes, if I keep pressing harder on the pedal, it will eventually reach the floor (I am already stopped by now-just pressing hard). If I let up and press again, it does not travel as far.
I was told by the dealer that this is normal?
Any thoughts out there? What are your trucks like?
Thanks for your input.
Brake Pedal Travel
I would second 94van. It sounds like a master cylinder to me. That's not what it is supposed to do. Now, brake fade is the amount that the pedal moves as the brakes heat up. All vehicles have fade, but the pedal should never, and I mean never, go to the floor. Something is wrong, I think.
Brake Pedal Travel
Originally posted by 94van
If you hold steady pressure on the pedal, and it slowly goes to the floor, that is usually an indication of an internal leak in the master cylinder. The master cylinder probably should be replaced.
What I am trying to find out is how do other F150s act out there? What does yours do? The dealer told me it was normal. If I get a list of people from here that tell me that theirs does not act this way, I will insist they find the problem. I have 50 miles left under an extended warranty and I want it solved before it expires...
Thanks.
Brake Pedal Travel
My '87 acts the same way yours does. If I stomp on the pedal it grabs really good. If I ease into the brakes they seem to take longer to catch, and I can lock the tires even though the pedal has gone down a long ways. My abs light is on, so that may have something to do with it too, if the valve is going out or is already shot. I have noticed that they seem to get better when I adjust the rears by doing the backup and hit the brakes method. My dad's '92 has a very firm pedal though. Whether I ease into the brakes or hit them hard, there's no difference, nice and tight.
Brake Pedal Travel
Originally posted by pfogle
as you apply {pressure} to the pedal the ABS system compensates by relieving the pressure
Nanook 1955
04-15-2016 02:01 PM
