Oil leak
Old Sep 2, 2012 | 06:16 PM
77mud's Avatar
77mud
Oil leak
Finally took the time to climb under the hood and wipe everything down, looks like the oil leak is coming out the bottom of the turbo,,,
See where the oil line is under the bottom of the Turbo... any one know where that is/could be coming from?
Old Sep 2, 2012 | 06:39 PM
427 fordman's Avatar
427 fordman
Pedestal orings, unless its the ebpv rod hole leaking. One of the two.
Old Sep 2, 2012 | 06:57 PM
77mud's Avatar
77mud
How hard/expensive is this to fix?
Old Sep 2, 2012 | 07:30 PM
427 fordman
If its the ebpv rod, you can remove it and plug it, easy, or you can get a rebuild kit if you still use/want it. If its the pedestal orings, turbo has to come off. That's not real bad, but one bolt really sucks that is under that housing the ebpv rod goes into. Neither one are expensive if you do it yourself.
Old Sep 2, 2012 | 07:47 PM
77mud's Avatar
77mud
Well im not smart on the Dizzle's... what is the ebpv? and how do i determine which it is that is leaking?
Old Sep 2, 2012 | 07:53 PM
427 fordman
That is the exhaust back pressue valve. It closes the exhaust in the cold to help in warmup. Lots of us have it unplugged or completely removed. On the turbo pedestal, backside, there is a round cylindrical(that word can't be right) looking thing that has a rod coming out of it towards the pass. side. That is the ebpv rod. If there is oil coming out of where the rod is, that could be your only leak. Look at that first. If its dry, its the pedestal orings. They could both be leaking, you never know.
Old Sep 2, 2012 | 07:59 PM
77mud's Avatar
77mud
When you say backside you mean like where the Down pipe comes off the Turbo?
Old Sep 2, 2012 | 08:04 PM
427 fordman
That silver/gray part in your picture with the oil on it has that ebpv housing on it on the back. That's the pedestal, and has orings right above where that oil is too.
Old Sep 2, 2012 | 08:08 PM
77mud's Avatar
77mud
Thanks. ill look into it further tomorrow when i take breaks from the 77 pissing me off lol Im hoping ill be able to fix it myself, but ive never done anything with a Diesel so i have no idea what id be doing, i have a couple buddy's who use to work with Cat and one of them runs his own Garage now, if i cant figure it out ill get them to give me a hand
Old Sep 2, 2012 | 08:43 PM
77mud's Avatar
77mud
i was talking to someone about it an he asked about exhaust blow by... i noticed some blow by the other day on it.. he said it was the ebpv mostlikely then
Old Sep 2, 2012 | 11:11 PM
oldbird1965's Avatar
oldbird1965
My money is on the pedistal O rings.
Old Sep 3, 2012 | 08:15 AM
77mud's Avatar
77mud
Thats sorta what I figured when i saw where it was coming from...
Old Sep 3, 2012 | 11:05 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Just for the info to the OP: the pedestal has two o-rings in the upper part and 2 o-ring in the bottom part. (two different sizes) All of them has to be changed.
Old Sep 3, 2012 | 11:32 AM
77mud's Avatar
77mud
guess that answer's my next Question of if the Pedestal has to come out to..
Old Sep 3, 2012 | 11:41 AM
oldbird1965
Yes, the pedestal and turbo come out, then the turbo comes off the pedestal for those two O rings whick are in between the turbo and pedestal. The other two O rings under the pedestal fit in a recessed area of the block of the motor. I think there is a write up on removing the turbo. Its doable but not fun because its very hard to get at the rear drivers side bolt holding the pedestal to the block.
