1978 - 1996 Big Bronco
not sure
Old Sep 1, 2012 | 07:57 AM
ericbatotbronco's Avatar
ericbatotbronco
not sure
Ok I have an 89 bronco with the straight six l300 and it sounds like I either have an exhaust leak or a loose or bad timing chain. It only does it when the engine is under a load ie when I have to get up and go. I have replaced the piston bearings in it so not that plus that would be a knock right? Some one please help me before I just blow it up or shoot it
Old Sep 1, 2012 | 10:49 PM
greystreak92's Avatar
greystreak92
Don't kill a perfectly good 300! (They really are nearly indestructible). If you are unsure where the noise is originating, you can try what I call the "poor man's stethoscope". Take a length of hose or even an paper towel roll and have a listen to various locations around the engine while it is idling. If you need to, have someone to increase throttle while you listen.
Old Sep 1, 2012 | 11:00 PM
ericbatotbronco
Thank you have done that and was it came from bearings. So I replaced them and no luck in truth it almost sounds like an old tractor.
bamafarmboy
Aug 28, 2015 07:37 PM
bra$$monkey
Nov 18, 2013 05:04 PM
F250saleen
Modular V10 (6.8l)
Jan 15, 2012 09:24 PM
bullfisher
Feb 3, 2011 08:07 AM
turboguy
20
Oct 21, 2005 04:54 PM
