hard to start
Old Aug 31, 2012 | 08:34 PM
jfdually's Avatar
jfdually
hard to start
my truck turns over but doesnot start on first attempt it will take two or three trys. fuel pump checked ok change fuel filter and plugs
Old Aug 31, 2012 | 09:14 PM
GwarForAll1021's Avatar
GwarForAll1021
How old is your battery? Mine use to start real bad. Got to the point where my radio would reset it was so bad. Finally figured it out put in a 1100CCA gold battery in and back to normal.
Old Sep 1, 2012 | 06:10 AM
jfdually's Avatar
jfdually
about year
Old Sep 1, 2012 | 12:00 PM
Coskid's Avatar
Coskid
You said fuel pump checked out OK but I just want to make sure you meant the Fuel Pump Driver Module that is located above the spare tire. Those corrode out and cause the truck not to run.
Old Sep 2, 2012 | 07:04 AM
jfdually's Avatar
jfdually
truck still runs it just takes a couple a times of turning key it starts fine in morning after sitting al night
Old Sep 2, 2012 | 08:01 AM
kbsupercrew's Avatar
kbsupercrew
Try cycling the key on and off three times before starting, to see if its a fuel pressure build up issue
cornstar6207
Dec 8, 2015 06:52 AM
brettdacosta
25
Oct 30, 2012 03:55 PM
aquaman
2004 - 2008 F150
Apr 8, 2012 08:12 PM
extazzz
1983 - 2012 Ranger & B-Series
17
Dec 17, 2006 10:33 AM
kdbbmanton
Aug 11, 2005 09:19 PM
