diablo predator ?
Old May 14, 2003 | 07:03 PM
tm29's Avatar
tm29
diablo predator ?
On the 60 hp setting it says 8,000 lbs weight limitations.
Is this gross vehicle and trailer weight, or just gross trailer weight
Old May 14, 2003 | 07:37 PM
FTE Ken's Avatar
FTE Ken
diablo predator ?
Gross trailer weight.
Old May 14, 2003 | 07:48 PM
tm29's Avatar
tm29
diablo predator ?
thanks alot for a fast reply
Old May 15, 2003 | 08:06 AM
SouthernDually's Avatar
SouthernDually
Post diablo predator ?
You stated that the weight limitations were 8000 lbs. If your really towing the weight limitations really limit what you can pull. I thought that the towing setup was for thoes that really pulled? Just a question. I pull a 12050 # trailer and thought that the setting would be a help. Am I wrong or did I missunderstand somthing. HELP.
Old May 15, 2003 | 07:54 PM
FTE Ken's Avatar
FTE Ken
diablo predator ?
The Predator's 40HP (all weight towing) pulls as hard as the Superchips 60HP. Its 60HP pulls about as much as the Superchips 80HP. That's why you see a difference in the tow ratings. If you're pulling 12K, put it in the 40HP mode or you can use higher modes if you have an EGT gauge and exhaust.
Old May 16, 2003 | 08:27 AM
SouthernDually
Thumbs up diablo predator ?
Thanks Ken..as usual another happy question answered.. I really do have to make some time to get over to the store.. Unfortunatly life tends to some times hand us more than we can get done...
moore1960
May 14, 2021 01:14 PM
jtpowderkeg
2015 - 2020 F150
Aug 4, 2016 09:13 PM
93-331-29PSI
6.7L Power Stroke Diesel
Dec 10, 2015 12:04 PM
crescentwrencher
Mar 17, 2008 12:57 PM
j-md
Jan 30, 2005 11:40 AM
