Door Panels
Old May 14, 2003 | 06:14 PM
alabamabuddog's Avatar
alabamabuddog
Door Panels
O K guys I have a 2000 Excursion / 92 F150 extended cab and a 81 Jeep CJ 7 I like working on them but I hate breaking any of them . I dont know how to remove the door panels on the side doors and cant see the standard push in fasteners. Will some one help me with removal of the door panel.
Old May 14, 2003 | 08:29 PM
birdman127's Avatar
birdman127
Door Panels
look for all the screws first, the door panel in the X after the screws are removed lifts straight up, not out like most auto's!
Old May 14, 2003 | 08:35 PM
alabamabuddog
Door Panels
sorry I dont see any screws in the door panel
Old May 15, 2003 | 12:20 PM
pancartom's Avatar
pancartom
Door Panels
i've had my door panels off on my sd truck (same doors)..... first, pull up, and slide forward the switch panels, one screw is hidden behind them. the other screw hides behind the door light lens. pop it off with a flat screwdriver, and you'll see the second screw. once the screws are out, lift up on the door panel, it'll come off after removing the bulb assy from the door light. hope this helps.
Old Jun 6, 2003 | 05:57 PM
Hardtimes's Avatar
Hardtimes
Door Panels
Once you take them off you can stop and thank Ford for finally doing somthing right and user friendly
Old Jun 6, 2003 | 10:36 PM
alabamabuddog
Door Panels
Yes it was a breeze to get them off once I learned how !
