3 yrs is up and it is time to flush the coolant. I am going to clean with VC-9, rinse with distilled and then switch to ELC. For everyone that has already done this, how's it going? Any problems? I am hoping between this and the coolant filter that my oil cooler will last forever.
What do you guys recommend for changes after a switch? I was thinking every 500K mi
I've been running Shell Rotella ELC for about 1-1/2 years with a coolant filter. Cut open filters are clean, deltas are staying 5-6 degrees. It seems to be working good.
I will be doing the same in the next year as well, with the exception of the chemical flush (I did one when changing out my EGR/Oil cooler last year). My deltas are fine right now and using the chemical flush method could potentially change that. I will be doing a comprehensive distilled water flush instead. Record your deltas before and after. It would interesting to see if any change occurs.
I'll definitely post my deltas after. Currently 8-9 around town, but 13-16 on the freeway hauling a$$. I am going to change my thermostat at the same time because I seem to run a bit cold - I am rarely over 200, sometimes not even 190 ECT. That may affect the spread as well. I'm still assembling supplies so it will take a while for me to get back to you on the spread change.
Sullid01,
Temps should be read at 65mph and after 20mins and level roadway. Not on the freeway hauling a$$. Why not try that and repost your numbers. Was that a typo on 500K next coolant change? Maybe 50K sounds a little better.
FYI ELC 1 year and no problems and coolant filter has a few casting sand grains in it. I've reached the point of 1 filter per year. 1-1-13 next filter. Same time as I change oils/fluids in my quads.
you're only doing half the chemical flush. You want to use Restore first, that is specifically designed to remove silicates. VC-9 (and Restore+) remove rust. You need to do each one (NOT TOGETHER!)
Sullid01,
500K mi was a joke.
About my deltas - 12-13 would be average for "cruising" at 65mph - it is all flat around here, but on the freeway traffic is usually moving about 80 so I go with the flow. BTW, I don't think I have a problem - I am just due for a coolant change (3 yrs). Someone asked about deltas so I posted (although I admit I never could remember when I was supposed to take the reading). I have an Insight so I watch the thing all the time.
About the Restore - I have had a coolant filter for over 2 yrs now and rarely find anything in the filter anymore - do you still think it is necessary?
I changed my thermostat also thinking it was faulty. The new one had the same results as the old one. On average it runs at 186 deg and usually doesn't go over 200 unless under load.
...About the Restore - I have had a coolant filter for over 2 yrs now and rarely find anything in the filter anymore - do you still think it is necessary?
from my understanding, yes, if you're changing type of coolant, you need to. All of my understanding comes from reading these forums, so it's just regurgitation, not knowledge. I would do it, yes.
I will be doing the same in the next year as well, with the Mexception of the chemical flush (I did one when changing out my EGR/Oil cooler last year).y deltas are fine right now and using the chemical flush method could potentially change that. I will be doing a comprehensive distilled water flush instead. Record your deltas before and after. It would interesting to see if any change occurs.
I agree with Vectrex.... if you are not having problems with your deltas, I would NOT do a chemical flush. It will likely plug your oil cooler and then you will be changing out coolers as well. I would wait until you have to replace an oil cooler/EGR cooler before doing a chemical fluch because at that point you will be changing them out anyways. Even with a distilled flush you may see temps lower by a few degrees..... or on the flip side they may also go up! Stats are more in your favor however if you do a distilled flush only vs. a chemical flush.
I don't believe the chemicals will increase your chances of removing all the gold coolant. Repeated dillution and comprehensive flushing should bring it to a level safe enough to switch to ELC, and I believe several members have used this approach safely.
The only thing I will be doing additionally is removing the block plugs to increase the amount of gold coolant removed with each flush. The plugs will be replaced with fumoto valves for ease of flushing. After seeing what came out of my chemical flushes, I would never do it on a healthy cooling system out of fear of clogging the oil cooler. It's an unnecessary risk in my eyes. It didn't take many flushes for me to obtain fairly clear water from the cooling system.
What do you mean "not many flushes" that looks like 30 something flushes.
What he said . If your not having temp problems then don't disturb it with VC9 .
Yep - that's exactly what I get. My delta's are a bit higher than yours are. I have 55Kmi on an original oil cooler. It seems like some of you think I am playing with fire doing the chemical flush. Should I just stick to the distilled water?
The picture is deceptive. The Restore flush included the original gold I drained out. When you take into consideration that you're gonna get 3+ gallons out of each flush, it's only like 4-5 flushes per treatment. With the thermostat removed (highly recommended) you can have this done in a couple of hours.
