intermittent no start
Old Aug 30, 2012 | 08:27 AM
SEAL1's Avatar
SEAL1
2001 explorer, SOHC. Sometimes just lately (5 times in the past three weeks) the engine just does not start. It turns over just fine but makes no attempt to actually start. When it does this it will after a few attempts start right up like nothing was ever wrong. It doesn't seem to matter wether it is cold or warm. Intermittent problems are very hard to diagnose so if anyone has any ideas, about common problems that would cause this, they would be appreciated.
Old Aug 30, 2012 | 12:11 PM
aquanaut20's Avatar
aquanaut20
Intermittent no start is commonly caused by poor contact in plug at the Crank sensor (down by the front dampener pulley)..and,
weak fuel system pressure..
Beyond that, what have you done in the diagnostic arena?? . Philip
Old Aug 30, 2012 | 12:41 PM
mercuryguy's Avatar
mercuryguy
Similar Problem 97 Explorer 5.0
See what happens if you remove the battery cable and leave it off for a bit.
I have a similar problem. Intermittant no start. In the winter it happened when engine hot, in summer it happens in the morning engine cold. If I remove the battery cable for 30 minutes or so, it will start. Once it starts, it runs and drives perfectly until it sits for several hours, then no start again. It has no spark when this happens. Fuel is fine. Any thoughts?
SEAL1's Avatar
SEAL1
Not much yet. It is the wife's vehicle and I just found out about the problem and she has the truck with her. I just thought I could do a lot less trouble shooting if know about any common problems that cause this.
I will check those this weekend when I get my hands on the truck and post my findings. I would think if it was weak fuel pressure it would show symptoms when accelerating or at high speeds also, which it doesn't.
Thanks for the reply. Steve
Old Aug 30, 2012 | 03:13 PM
aquanaut20's Avatar
aquanaut20
Tired fuel pumps may be too tight to pump efficiently having sat for a while, several start attempts may jump start the fuel pump allowing to spin up and create pressure, it needs to be tested.....or not, your choice!...
Same goes for high resistance connections..... Philip
Old Aug 30, 2012 | 04:43 PM
SEAL1's Avatar
SEAL1
I appreciate the explanation of the fuel pump and it will get tested. Thanks.
Old Sep 7, 2012 | 07:12 AM
SEAL1's Avatar
SEAL1
Fuel pressure tested OK. I also didn't find anything wrong with the crank sensor. None of this surprises me because it is a very intermittent problem that seems to clear itself by itself very quickly. She tells me it hasn't happened since she told me about it. I hate to do this but I suppose I will have to just wait for it to totally quit or at least for it to become more frequent. Thanks for the input and I will revisit this thread if or when I figure this out.
Old Sep 17, 2012 | 12:50 PM
Rick03F250's Avatar
Rick03F250
my wife also just reported the same thing yesterday, whats the fuel pressure supposed to be when you turn key and then running?
Old Sep 17, 2012 | 01:37 PM
SEAL1's Avatar
SEAL1
30-65 PSI is normal.
Old Sep 17, 2012 | 01:40 PM
Rick03F250's Avatar
Rick03F250
Thanks SEAL1, I'll have to look at it tonite
Old Sep 18, 2012 | 05:07 AM
Rick03F250's Avatar
Rick03F250
UPDATE: DEAD battery, only had 107cca, fired right up with new battery
thanks all
Nightrider41
Jan 7, 2015 06:44 AM
IDAH0.REDNECK
Feb 8, 2013 10:47 AM
traildogg
Jul 9, 2009 08:48 AM
mikemustang289
20
Oct 7, 2006 05:06 PM
jbain2
Jun 25, 2003 07:12 AM
