sct tuner questions
-Is the tuner legal and going to pass smog in California? Or do I need to set the truck back to stock before getting it smogged in CA? I read somewhere that you can only set it back 5 or 6 times before it locks up and I plan on keeping this truck for a long time.
-I know Mike needs to know if the truck is a 2v or 3v. How do you tell?
-Also I was thinking of doing something with the exhaust. I don't really want to do any headers only because I have had them leak on me and it's a pain to get to the passenger side. I was thinking of putting a magnaflow muffler on. Don't know if that alone would help at all or just give me a different sound. It looks like I can't do anything with the catalytic converter since everything I see online says not for use in California. This state blows. Any suggestions on the exhaust side would be appriciated. Especially if you have something set up and are in CA.
-I did replace the plugs and put a K&N filter in it. I also replaced the fuel filter. I don't think it had ever been changed. It looked like the Mississippi river when it's flooded; and that was on the "CLEAN" side. I did notice a little bit of a power difference and it got rid of my pinging that I had, but I'm sure a dirty filter like the one I had can do that. It runs much better but now I would like some more power.
Sorry this post is a little on the long side. The more I drink the less I write and this is a little long...;-)
I'm sure I will have more questions later on. Thank you for any reply.
As I understand it you can change the program as many times as you want. The five time limitation applies to the being locked to the VIN and not the dealer down load.
Check out the web site for more accurate information.
Your truck is a 2v, as are all 99-04s. I would recommend an MBRP muffler.. i just put one on my truck to replace the quiet gibsons and it sounds GOOD. tons of compliments
F250 5.4L MBRP muffler - YouTube
Technally no because you are modifying the fuel program but you just reoad the OEm before going to the sniffer. The limit does not have to do with how many times you switch it on your truck. When you load a program it locks to the VIn of that truck. The lock number is how many different VIN you can link to it I believe.
Actually he needs the program revision number. It's on a label on the computer or if you already have the tuner you can read it, This will tell him exactly what you have and whatprogram to send you.
The leaking problem seems to be more with the bolts/studs holding them on from what I've read. Changing the y pipe helps a lot. It's kind of a choke point the way it's made. You can do headers as long as they have the EGR port fitting.
Pinging can be caused by a dirty aif flow sensor too. But the easiest power improvment is the 5-star tune. Then exhaust modifications. Mike can adjust and update the program for you as you do any other mod.
Does the Y pipe bolt right up to the stock manifold and current exhaust or does it require some welding and custom fitting?
ACF6 I will check out the video as I cannot now since I am on lunch break at work and they block videos. Do you have headers and any other mods to the exhaust or just the muffler? Cat stock?
