Kickdown and throttle linkage
Old Aug 29, 2012 | 09:15 PM
nvrgrwup's Avatar
nvrgrwup
Hi all. Haven't been on in a while but have a new project. '72' F-100 short bed. The problem is how can I highlight the vin stamping on the frame to better be able to read it? Is there a chemical that will make it more visible? I can read most of it but am missing the first five digits/letters.
Also, I suspect it is an original 390 truck, but don't know for sure. It has an Edelbrock carb but whoever put it together didn't hook up the kickdown and throttle linkage correctly. Do any of you have a picture of an original big block/auto linkage on the carb as well as the bellcrank on the intake and firewall hookup? Trying desperately to keep it as original as possible so it works correctly. I have the bellcrank and firewall setup but don't know how to connect to the new 4 barrell. Any help will be greatly appreciated. Thanks, Russ.
Old Aug 30, 2012 | 07:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by nvrgrwup
I suspect it is an original 390 truck, but don't know for sure..
The 4th digit of the VIN is the engine code. 1968/72 F100/350:
A = 240 1V I-6 / B = 300 1V I-6 / G = 302 2V (1969/72 F100 only) / H = 390 2V / Y = 360 2V
Old Aug 30, 2012 | 08:30 AM
nvrgrwup's Avatar
nvrgrwup
Hey Number Dummy, thanks once again! THe first half of the stamping is so faint I can't read it all. Looking for some sort of dye maybe that will show it up. I know there is such a thing. Maybe a machine supply. Anyway, when I get the whole vin I'll be giving you a shout out, thanks again, Russ.
Old Aug 30, 2012 | 11:38 AM
19704X4F250's Avatar
19704X4F250
This is for a factory 2 bbl but it should get you close.....
http://www.fordification.com/tech/im...nkage_8cyl.jpg
Old Sep 1, 2012 | 11:31 PM
nvrgrwup's Avatar
nvrgrwup
Hey Dan, thank you. Just what the doctor ordered! I can print that off and a little patience and 3 or 4 brews I should have everything hooked up. The FTE forum comes through again, thanks, Russ.
Sassypaints
Aug 10, 2019 03:32 PM
dorf dude
16
Sep 22, 2015 06:15 AM
JRM1972
16
Mar 11, 2013 08:59 PM
77BlackBetty
Feb 13, 2009 01:42 PM
Seth8605
27
Mar 26, 2004 10:38 PM
