HELP!!!!
Old Aug 29, 2012 | 01:11 PM
rowbaird's Avatar
rowbaird
HELP!!!!
ok let me first explain what my intentions are with the project truck i am working with. i have a 93 f250 body that i am wanting to put a newer direct injection motor in. ok so i bought a motor and the vaulve cover stamp is gone so everyone else that i have saw online speaks of the block serial number and i found the number it is 7.4JU2U 2 4 5 7 0 6 AND I HAVE CALL EVERY ONE I MEAN EVERONE about this to find the year of the motor and usaially you know it wouldnt be this hard just put you motor in and the biggest thing would be the wiring but no thor i bought was out of an automatic and was told to be to be a 96 but when i went to do a swap to a manual the the flywheel wont go on the back of the crank because the ring on the back of the crank is larger than the slot on the flywheel so thats why i am having troubles so if any one at all knows what my year of motor is it would be very helpful for your help because ford cant look it up with out a vin and international cant help me at all so please heeeeeeeeeeeelllllllllppp
Old Aug 29, 2012 | 01:37 PM
rodneywar's Avatar
rodneywar
if the motor was from an automatic it will have a spacer that has to be removed to be able to use the flywheel from an manual the spacer is on the crank
Old Aug 29, 2012 | 02:11 PM
fordpride's Avatar
fordpride
(engine serial no. 201680 & before) is 1995 and down
(engine serial no. 201681 & up) is 1996 and up
Old Aug 30, 2012 | 11:55 AM
rowbaird's Avatar
rowbaird
but even if i take that spacer out the flywheel will not go on at all the ring on th back of the crank is bigger than the one on the flywheel i mean i did get the clutch from advanced thats probably the problem
Old Aug 30, 2012 | 12:58 PM
DIYMechanic's Avatar
DIYMechanic
I think you have the wrong flywheel. You likely have one for a '96 and down engine and you have a '96 and up engine you're trying to put it on.
Here, Check out these links courtesy of Rock Auto:
Dimensions for a flywheel listed for a '95 7.3 PSD.
Dimensions for a flywheel listed for a '99 7.3 PSD
Can you verify this by which flywheel you asked for? Also, if you look at the top of the valve covers, where the wiring goes through the valve cover gasket, how many wiring connectors are on the VC on each side? A '97 and down engine will have two per side, a '99 up will have one per side.
Old Aug 31, 2012 | 06:40 AM
Talyn's Avatar
Talyn
Good info guys. I'm in rep jail still.
Old Aug 31, 2012 | 09:34 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I could sent rep to Mike but I couldnt to Nate
Old Aug 31, 2012 | 01:23 PM
DIYMechanic
That's alright Jose. It's the thought that counts right!? LOL.
Old Sep 4, 2012 | 06:31 AM
rowbaird's Avatar
rowbaird
everything went well spacer came off the back of the crank and is now all bolted up to the trans now all that is left is the wiring is there anyone that knows anone that what kind of job its going to be to wire a 96 direct inject into a 93 body
Old Sep 4, 2012 | 06:37 AM
fordpride's Avatar
fordpride
You'll need the under hood wiring, in cab wiring, IDM, PCM, speedo from a 94.5-97 PSD
This is what you need to take care of the wiring issue
Old Sep 4, 2012 | 06:39 AM
DIYMechanic
Was it the wrong flywheel?
Old Sep 4, 2012 | 07:03 AM
rowbaird's Avatar
rowbaird
That spacer that was behind the automatic flywheel was much bigger than the one for the manual i pulled out the spacer and the manual flywheel fit right on. you got any idea on my wiring issue
Old Sep 4, 2012 | 07:04 AM
rowbaird's Avatar
rowbaird
not nessarly bigger in size but the inside cut out is much bigger on the auto trans than the manual
Old Sep 4, 2012 | 09:42 AM
fordpride's Avatar
fordpride
Devore95
Feb 24, 2014 02:42 PM
Mudslinger77
Apr 21, 2010 03:51 PM
dodgemahal
Dec 28, 2004 09:28 PM
cobrajet
Jul 8, 2001 10:45 PM
