Coolant? Interesting
Old May 14, 2003 | 01:42 PM
sidecarman's Avatar
sidecarman
Unhappy Coolant? Interesting
Hi all, have been lurking and learning, not necessarily in that order. I have a 94 F150xlt 5.0 auto with 122,000...Always loosing small amount of coolant and cannot find leaks anywhere and it has not leaked into the oil system. Don't ask how I know this. But when I park in lot with engine higher than tail by 1 or more feet, the coolant leaks out muffler Is this a head gasket? let me know your thoughts. Thanks,
sidecarman
Old May 14, 2003 | 02:52 PM
gasman6674's Avatar
gasman6674
Are you sure its coolant and not condensation?
I would suggest you take a hard look at all of your hoses, Including the little hose that warms the throttle body. Also look at your thermostat housing the paper gasket has a bad habit of leaking. I replaced a water pump because of one. You can run (or have run) a compression test and a cylinder leak down test to rule out a head gasket. I have a 92 with a 302 136,000 and have had to replace all of the hoses.
Hope this helps
Old May 14, 2003 | 03:01 PM
sidecarman's Avatar
sidecarman
Jim, thanks, I will look at all hoses and thermostat... Yes, I know the taste and color of the coolant, but I also look for ideas of other things that may be wrong.
sandy
ps:when I park truck angled other way there are no leaks at the front.
