Reman engines?
Opinions please.
EngineGuy.com Factory Tour 972 919 0220 - YouTube
I do, however, want to encourage you to do a compression and/or a leak down test, and a good look at oil pressure, to see what you're dealing with, before spending too much money. The bottom end of these engines are incredibly long lived with even a minimal amount of preventive maintenance.
You might very well get by with a top end overhaul and not have to even touch the bottom. If you want to go to PI heads, you will have to have the matching intake manifold, and it might very well be that you could get the whole setup somewhere and take care of everything on an exchange basis.
Woops! I just re-read your post and noticed 5.4. I'm not intimately familiar with the 5.4 as opposed to the 4.6, but I think the PI heads only apply to the two valve motors. Maybe there was also a Performance Improvement program for the 5.4 as well. I know there have been several different heads over the years.
Hope this helps.
Hope this helps.
I'm sure you know what a PITA doing Leakdown and compression test are on the F150 5.4L. There's baring room to install the plugs once lest screwing in adapters back and forth to get the results? It was no fun getting those rear plugs out and back in without stripping them or getting dirt in the cylinders.
I've never been a fan of buying a used engine, but I'm an old geezer that goes back to the days when engines didn't last very long.
Best of luck with it and keep us posted.
Blown head gaskets would probably not result, but being unable to run on pump gas would very likely be your problem.
Sorry I'm not up on the 5.4 parts interchangability issues. I know a little of this with the 4.6. I didn't even know that the 5.4 ever had a power improvement program.
I'll be interested in learning about what you come up with. Keep us posted.
