New U-Joint Tool
Old May 14, 2003 | 10:11 AM
jbalestri's Avatar
jbalestri
New U-Joint Tool
After doing many U-joints with a hammer and an old king pin, I finally ruined one. I thought about getting a U-joint kit, with the presses and all. But all the shops were closed and we had to come up with some sort of a press, the vice just wasn't big enough.
My father in-law saw one of these, hanging on his wall.
Man that made the job alot easier and worked like a charm. Just thought I would pass it on. No more beating with a hammer, or anything. We used a big socket on the end that the cap goes into, and a smaller socket on the press end. Then just tighten the clamps up and it presses the trunion caps right into place.
Old May 14, 2003 | 01:58 PM
z 97ford1's Avatar
z 97ford1
New U-Joint Tool
I just bought a new one for $90 at santa fe tools.......well worth the money paid.
It pays for itself the first time you use it.
Old May 14, 2003 | 02:04 PM
billman's Avatar
billman
New U-Joint Tool
I have used my bar/pipe clamp every time- works like a champ.
Old May 14, 2003 | 02:09 PM
jbalestri's Avatar
jbalestri
New U-Joint Tool
97ford...
Are you a fellow Albuquerquen? If not, where else is Santa Fe Tool. I thought that was a Albuquerque thing?
Old May 14, 2003 | 05:32 PM
z 97ford1's Avatar
z 97ford1
New U-Joint Tool
santa fe tool is in albuquerque........I live in phoenix.
Look under "astro pneumatic tool company" if you want to buy one. It's made in taiwan and just as good as american made.
Old May 15, 2003 | 11:59 AM
KJKozak2's Avatar
KJKozak2
New U-Joint Tool
I never thought of using my pipe clamps as a press.
Ironically, I used my pipe clamp last week to prop up the other end of the shaft while I pounded the joint out. Duh!
Thanks for the tip.
Kevin K.
Old May 15, 2003 | 12:11 PM
superswamper's Avatar
superswamper
New U-Joint Tool
i can see how the pipe clamp would help putting the cross caps in but are there any cool tricks for popping out a u joint?....i'd rather not hammer....that means taking the drive shaft all the way out of my truck and when i break it i'd like to get right back to driving as soon as possible you know.
btw i've call about every drivetrain/ tool place in my area and they've never heard of any kind of ujoint tool, except the presses of course
Old May 15, 2003 | 12:35 PM
rebocardo's Avatar
rebocardo
New U-Joint Tool
They sell UJ tools in the northerntools automotive catalog. They are in the NAPA catalog too. I use a balljoint tool kit with an impact gun for my stuff.
Old May 15, 2003 | 12:38 PM
KJKozak2's Avatar
KJKozak2
New U-Joint Tool
The pipe clamp might work both ways if you use penetrating fluid and some heat.
K.
superswamper
New U-Joint Tool
so a ball joint puller will work as well, what about just a regular three hook puller?
Old May 15, 2003 | 12:40 PM
jbalestri's Avatar
jbalestri
New U-Joint Tool
rebo,
I never thought of using my balljoint separator. What an awesome idea. Use that to take them apart, great. I'll have to see if it fits the driveshaft.
Thanks
Old May 15, 2003 | 03:00 PM
TallGuy_Az's Avatar
TallGuy_Az
New U-Joint Tool
Those things are great tools. I use the ones I have to do u-joints and also for squeezing the brakes back in to put on new brake pads. They come in handy.
Old May 15, 2003 | 03:57 PM
beartracks's Avatar
beartracks
New U-Joint Tool
I use a large "C" clamp. The one I have has pads that fit into the holes on the yoke so it can press them all the way in.
zxwut?
34
Sep 23, 2024 10:08 PM
labman1014
Aug 8, 2012 10:23 AM
mechelement
Oct 12, 2009 01:26 AM
tchad07
Offroad & 4x4
Aug 2, 2007 05:56 PM
