Axle question
Old Aug 26, 2012 | 11:28 AM
Rocky Mountain F150's Avatar
Rocky Mountain F150
Axle question
1995 F150 4x4 with Dana 44. Replacing rotors today and I pulled the spindle as well for a new bearing. On the passenger front the spindle came off and left the axle inside the rubber boot...on the drivers side however the axle came with the spindle and I saw gear oil running out of the front pumpkin. I quickly shoved it back in and then separated the spindle leaving the axle in (when I say axle, I mean the u-joint inward).
Is it ok? I can't see in there due to the frame and stuff. Is there a rubber boot or something? A seal I need to check out or replace? Or is it just fine I put it back in and button everything up? Should I top off the gear oil in the pumpkin?
Old Aug 26, 2012 | 12:11 PM
BigBlueOx's Avatar
BigBlueOx
That is normal. There IS a seal on the diff that it goes into. Now is the time to replace that seal if it needs it.
It wouldn't hurt to check the diff fluid though.
Old Aug 26, 2012 | 12:37 PM
Rocky Mountain F150
Had to put it all back together last night but I guess if it starts leaking I know it'll be that seal up in there. Is it hard to reach? I couldn't seem to find a way to get to any seals where the Dana front diff pumpkin is.
Old Aug 26, 2012 | 04:25 PM
BigBlueOx's Avatar
BigBlueOx
The seal is nearly impossible to change with the diff still attached to the traction beam. If it wasnt leaking before im sure it will be fine.
Old Aug 26, 2012 | 06:31 PM
minnesotafisherman's Avatar
minnesotafisherman
Yep, no way your going to change that seal without pulling the front diff... when I converted mine to 4x4, took everything entirely apart, replaced EVERY seal in the D44, then put it back together with fresh fluid and into the truck. Should take a long time before it starts to leak..
blueoval77
Dec 5, 2007 10:10 PM
Tim Young
1966 - 1977 Early Broncos
Oct 5, 2006 10:49 AM
SMB
Jul 13, 2004 08:19 AM
SMB
Jul 6, 2004 12:18 PM
gcfisher75
Nov 23, 2003 09:57 AM
