Transmission Cooler
Old Aug 25, 2012 | 08:40 PM
donmi's Avatar
donmi
Transmission Cooler
Hi there,
somebody told me, the biggest heat problem with the 1993 7.3 IDI comes not from the engine, it comes from the transmission. I was told to install a big transmission cooler instead of the fabric installed one.
The combined weight with our 5th wheel is between 18,000 and 19,000 lbs.
There are various aftermarket tranny coolers out there, does somebody have a recommendation??
Thanks
Michael
Old Aug 25, 2012 | 09:18 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
Tru-Cool max cooler from dieselsite.com is what i have.
here is mine.
https://www.ford-trucks.com/forums/1...on-cooler.html
Old Aug 25, 2012 | 09:21 PM
'94IDITurbo7.3
do you have a trans temp gauge? if not then get one.
here is a link to the cooler.
http://www.dieselsite.com/specialord...ioncooler.aspx
Old Aug 25, 2012 | 11:51 PM
donmi's Avatar
donmi
Hey,
thanks, this was helpful. I think is a good idea to get one pretty soon...
....incl. gauge.....
Michael
Old Aug 25, 2012 | 11:52 PM
donmi's Avatar
donmi
Did you use the original hoses???
Old Aug 26, 2012 | 06:32 AM
fuzzy1626's Avatar
fuzzy1626
The cooler should come with new hose. You want to put the aux. cooler in line with the cooler in the radiator. From trans to radiator cooler out to aux. cooler, an back to trans.
Old Aug 26, 2012 | 10:27 AM
'94IDITurbo7.3
yes the new cooler comes with new hose. that chunk of hose you can see in my pics in my first link is what comes with it. i had to buy a 5/16" diam length of hose though. i used the 3/8" that came with the cooler, but needed more so i got the 5/16 which is the size of the metal lines coming from the trans. surprisingly the 5/16" hose fit just fine over the 3/8" hose barb on the cooler.
yeah you want to put this aux cooler after the cooler in the rad.
Old Aug 26, 2012 | 07:40 PM
Cowman79's Avatar
Cowman79
I just put a tru cool max on my truck and it made a big difference. The install only took about an hour.
Old Aug 26, 2012 | 07:49 PM
'94IDITurbo7.3
any pics of your install cowman?
Old Aug 26, 2012 | 08:07 PM
Cowman79's Avatar
Cowman79
I have some pics but not sure how to load them.
Old Aug 26, 2012 | 08:16 PM
'94IDITurbo7.3
you can create a photobucket account(free to do), then upload pics from your computer to photobucket, then copy the image code into your post on here.
donmi's Avatar
donmi
I just got an cooler today, will be installed at the end of the week,
Also I will install a gauge for the oil temperature in the transmission. Looking for one with Celsius............ just kidding I don't mind...
Old Aug 26, 2012 | 08:24 PM
'94IDITurbo7.3
so did you go with the tru-cool max cooler?
Old Aug 26, 2012 | 08:27 PM
Cowman79's Avatar
Cowman79
Pics of my transmission cooler install and a few other projects this weekend.
Pictures by cowman79 - Photobucket
Old Aug 26, 2012 | 08:38 PM
'94IDITurbo7.3
nice. now when ever you want to post a pic from there into a post on here, hover over the image you want and you will see the 'img code", just click on that and then come to the post and hit paste.
