steering gear info
Old Aug 25, 2012 | 06:16 PM
62star's Avatar
62star
steering gear info
i have a 95 E 150 and need any info possible about replacing the power steering gear box and tie rod ends.
Old Aug 25, 2012 | 07:40 PM
95e150CW's Avatar
95e150CW
Nothing special, just like any other truck. Take them off, install the new ones, get it aligned.
Old Aug 25, 2012 | 07:50 PM
avenge's Avatar
avenge
I haven't done my steering box yet but I think you need an idler arm puller and there's 3 bolts holding it to the frame. You want to remove it with the steering wheel centered.
For the tie rod ends you may also need a puller or fork. Measure from the center of the tie rod to the end of the threads before removal, install the new ones the same distance with new cotter pins.
You should have the alignment at least checked when done.
Try "search" you'll probably wouldn't even have to post your question.
Old Aug 26, 2012 | 06:42 AM
62star's Avatar
62star
thanks guys
Bowie
Jun 10, 2017 07:00 PM
cabloom300
Jul 25, 2013 01:32 AM
1yamman350
1983 - 2012 Ranger & B-Series
Aug 14, 2003 07:38 PM
