DJM Shackle?
Old Aug 25, 2012 | 04:54 PM
CB-R's Avatar
CB-R
DJM Shackle?
Anyone out there have pictures of these installed? I know that they are supposed to be a direct swap, but they don't look much like the shackles on my truck. It's a 71 f100 LWB. Do I need to use a bolt on the front of the shackle to engage the spring or what? The stock setups shackle is continuous across the width of the spring. Hope this makes sense. Thanks in advance.
Old Aug 25, 2012 | 06:27 PM
HIO Silver's Avatar
HIO Silver
Identify your system by going to LMC's website and refer to the catalog's drawings. You either have a regular shackle or the groovy Flex-o-matic system.
We'll figure it out once ya figure out what ya have.
Old Aug 25, 2012 | 09:21 PM
CB-R's Avatar
CB-R
Whoa! I've never been there before. What a catalog! Thanks for getting me going. Judging by the pictures they have, it looks like my truck has the flex-o-matic set up going on. Of course the DJM's that I have don't look like that. Whats next?
Old Aug 25, 2012 | 10:14 PM
HIO Silver's Avatar
HIO Silver
Well son, I suggest ya peruse the vendors that more or less can cater parts for our rigs. Visit and bookmark the sites below and order the free catalogs.. makes good reference material during reassembly too....
With regards to shackles, I believe you'll have to delete the Flex-o-matic system in order to use the DJM shackles.
The Usual Suspects:
Jeff's Bronco Graveyard
National Parts Depot:Ford Truck Parts & Accessories | 1948-1979
LMC Truck - Ford Truck Parts and Truck Accessories
MAC's Antique Auto Parts
Blue Oval Truck Parts
Dennis Carpenter Ford Restoration Parts
Speedway Motors, Street Rod & High Performance Parts
RockAuto Auto & Truck Parts
Carolina Machine Engines-Rebuilt Long & Short Blocks
Summit Racing
Shock Warehouse
Inline tube The brake plumbing experts
Benchworks Steering
Red-Head Steering Gears, Seattle WA
Borgeson Universal Steering Components
Old Aug 25, 2012 | 10:24 PM
CB-R's Avatar
CB-R
Well that's unfortunate info. I guess I'll way the ol cost to benefit ratio of this project and go from there. Thanks again for your help, HIO. You got me passed the hard part.
Old Aug 25, 2012 | 10:54 PM
HIO Silver's Avatar
HIO Silver
About the cheapest way to lower the rear is to flip the front leaf spring hangers... about $7 worth of Grade 8 hardware but it requires some sweat equity to remove the rivets.
.. the shadetree (yet effective!) way to remove the rivets is to cut the heads with multiple Xs and then grind down what is left of the heads flush with the frame. Then ya take about a 3-pound maul to a center punch and drive them out. Takes some work but hey, it does get the job done with minimal monetary input.
Old Aug 26, 2012 | 01:54 AM
jonboy2427's Avatar
jonboy2427
just dont use the flexo i didnt on mine. and for the front hangers a grinder and regular hammer an screw driver will do fine.
Old Aug 26, 2012 | 01:55 AM
jonboy2427's Avatar
jonboy2427
i have a 68 f100 by the way. cut two coils in front to level
jonboy2427's Avatar
jonboy2427
i have a 68 f100 by the way. cut two coils in front to level. ur gunna have to cut railing under bed also shackles will hit
Old Aug 26, 2012 | 10:51 AM
CB-R's Avatar
CB-R
How much drop will flipping the axle produce? I only want 2-3" Jonboy, what do you mean by don't use the flexo? Are you saying use the DJM parts somehow? Or is there a way to eliminate some stuff without putting regular springs on? Thanks again guy's.
Old Aug 27, 2012 | 10:49 AM
MIKES 68 F100's Avatar
MIKES 68 F100
any pics of the stance jonboy2427 ? been thinking about dropping mine just a little and this is on the cheap .
jonboy2427's Avatar
jonboy2427
4 inch is the max on the jdm steup. i took the flexo out just bolted to the leaf eyelet and hanger
Old Aug 27, 2012 | 11:19 PM
Thumper19's Avatar
Thumper19
if you have flex-o-matic shackle setup, all you do is remove that shackle and put in the djm ones.
DJM is sub-par quality though. I suggest you look elsewhere. AIM sells better quality brackets
Old Aug 27, 2012 | 11:57 PM
elgemcdlf's Avatar
elgemcdlf
That was a huge mistake
Old Aug 29, 2012 | 10:09 PM
CB-R's Avatar
CB-R
Okay, I'm on board with this input now. I hadn't been reading correctly for a few day's and missed some critical info. HIO, you're saying to flip the front hanger and reinstall. Not flip the axle as I was reading it to be. And Thumper, you're saying ditch the flex-o shackles and bolt up the aftermarkets. (I'll stick with the DJM's because I have them. Thanks for the advise though). So, my questions for now are how much drop will flipping the front hanger yield, and will the djm's still take another 1-2" out after that? And does anyone have a picture of what these parts look like all assembled? The flex-o is confusing me, and when I google search djm shackke images, nothing usefull shows up.
Thanks again for all your help, fellas. I'm excited to get the rake outa this rig!
