E4OD Issue
Old Aug 25, 2012 | 03:05 PM
dieselbro's Avatar
dieselbro
E4OD Issue
I have had my E4OD rebuilt on my 97 F250 Powerstroke. Ever since then, when it is warm, when I shift into reverse it lugs down like it is in a higher gear and backs up fairly fast, after a moment or two, it will feel like it downshifts again and reverses normally. Also, after a drive on the highway when I come off the ramp and stop at an intersection, again, it lugs down and wants to move forward, I have to apply the brake heavier, then it feels again like it downshifts to normal, then it will lug down again and try to move like it is in a higher gear. Once it is fairly warm, it will do this every time I stop at an intersection. I have taken it back to the shop on numerous occasions but they cannot find the issue. Any suggestions?
Thanks, Kevin
Old Aug 25, 2012 | 03:19 PM
Lead Head's Avatar
Lead Head
Sounds like your torque converter is not disengaging properly.
Old Aug 25, 2012 | 05:33 PM
dieselbro's Avatar
dieselbro
After the rebuild, (6 months ago) the first TC failed. This one was installed three days ago and it is still doing the same thing. What would cause it not to disengage?
Old Aug 25, 2012 | 05:51 PM
danr1's Avatar
danr1
Yea I agree first thought came to mind what Lead Head suggested.
First thing I'd look for is a short to ground someplace in the TCC lock up circuit. Something like that, an intermittent/varying short direct to "ground" causing the TCC to lock or partial lock when its not supposed to? could easily cause what you describe and would kill a TC pretty quick.
What its "temperature" has to do with it, happens warm but not cold be hard to say but that be first thing I'd check into.
If came to it install an OFF|AUTO|ON switch in that circuit as so I could turn it off verify that is exactly whats going on. If does verify that's what is happening switch also offers added benefit of manual operation/control until narrow down exact cause, save on the TCC retaining use of truck.
I don't have a diagram for a 97 Powerstroke so can't pin point wire color for ya.
Old Aug 25, 2012 | 07:17 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
purple wire w/ yellow tracer.
Old Aug 25, 2012 | 08:32 PM
danr1's Avatar
danr1
Oh ok yea same as gassers then, thought it probably would be but didn't want to assume as much.
Old Aug 26, 2012 | 10:07 AM
Lead Head's Avatar
Lead Head
Control circuit issue as mentioned could do it.
But judging by the fact that it's already eaten through a converter, I'd wager that the valve body is warped and is letting fluid bypass something. It is very easy to warp E4OD/4R100 valvebodies if you are not careful.
Old Aug 26, 2012 | 07:26 PM
dieselbro's Avatar
dieselbro
Thanks for your replies, Kevin
williameub
16
Jan 11, 2016 04:39 PM
daddylee100
Jan 10, 2014 05:50 PM
Garry1957
Feb 15, 2009 03:09 PM
Jerrybo66
Jun 16, 2006 05:11 PM
DWMAC
Nov 25, 2002 10:22 PM
