1979 302 compression test results
Old Aug 25, 2012 | 07:35 AM
alexchavel's Avatar
alexchavel
Finally did my first ever compression test, on a rough running 302.
Engine was rebuilt about 10,000 miles ago, ran great until suddenly power dropped on highway and started to hiccup.
Here are the readings I got:
1- 130
2- 120
3- 35 !!
4- 130
5- 155 ??
6- 135
7- 120
8- 140
So clearly cylinder 3 has a big problem, but 5 also looks too high no?
What is the general rule on acceptable highest/lowest reading?
If 3 is SOO low what am I looking at?
Old Aug 25, 2012 | 10:44 AM
daveengelson's Avatar
daveengelson
Not that knowledgable but just happened to have done a compression test recently; beleive the ratio is around 20% difference between high/low. If the max reading is running around 155 then the min. should not be lower than between 115-117. Except for #3 appears the other's are within limits. Definately somethings going on with #3, suggest try adding a drop of oil in the cyl. and if there's an increase then possibly rings; although, with that much of a difference possibly head gasket but suspect valve, or valve seat issue. A ' leak down' test would probly pin point the problem.
Old Aug 25, 2012 | 11:01 AM
alexchavel's Avatar
alexchavel
If I add a few drops of oil to the cylinder, there you should a small increase in pressure either way right? If the rings are still good?
Is it a big increase in pressure that would confirm a ring problem?
Old Aug 25, 2012 | 11:24 AM
daveengelson
3-5 drops of oil with an increase in compression is an indication rings are worn, no significant increase in compression is an indication the problem is with valve or head gasket. The results of the compression test on my 302 is that the cyl. were all within limits; however, there are a couple of cylinders where it would take 5-6 cranks to reach max.( increase in reading with each stroke) which according to neighbor (machanic) is an indication the rings are slightly worn.
Old Aug 26, 2012 | 12:07 AM
willowbilly3's Avatar
willowbilly3
A difference of 10% between high and low is acceptable. #3 definately has an issue, my guess is a valve.
Old Aug 26, 2012 | 06:11 AM
alexchavel's Avatar
alexchavel
Hi willow billy
A buddy of mine was saying a valve too
Im going to take the valve cover off on the side which was number 3 and turn the engine over by hand, see of I can see anything abnormal on number 3
What are specific things I should be looking for? Broken spring? Bent or broken valve?
Old Aug 26, 2012 | 01:16 PM
alexchavel's Avatar
alexchavel
So I did a wet compression test on #3 and there is no increase in compression whatsoever.
Valve problem then I assume?
I took the valve covers off, don't see anything abnormal at quick glance, will have a helper tomorrow to turn engine over by hand while I check valve movement on 3
What should I be looking for exactly??
Old Aug 26, 2012 | 04:18 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Whether or not it's sticking would be about the only thing you can see with the head on the vehicle.
Old Aug 26, 2012 | 04:28 PM
alexchavel's Avatar
alexchavel
Damn...don't have much time to fix it!
If I do see it sticking what is the solution?
Old Aug 26, 2012 | 05:14 PM
alexchavel's Avatar
alexchavel
We use the vehicle as the band van on tour, leaving next Sunday!
If I do happen to see a sticking valve what are my options?
I was hoping to see a broken spring or something else I know how to fix.
Someone local is selling a set of barely used 302 heads for a bargain, so I guess I could swap em out by next sunday and deal with this problem later.
Old Aug 26, 2012 | 05:35 PM
BaronVonAutomatc
If it's sticking you'd need to figure out why, which means yanking the head. Could be a burnt valve/seat, slightly bent valve, who knows. Maybe a valve job fixes it.
Old Aug 26, 2012 | 06:48 PM
alexchavel's Avatar
alexchavel
Yanking heads mean pretty much everything has to come off right?
Damn...
Old Aug 27, 2012 | 09:25 AM
BaronVonAutomatc
Everything above the deck, yes. I would consider it major surgery.
Old Aug 28, 2012 | 05:43 PM
alexchavel's Avatar
alexchavel
I don't have a leak down tester, only compression gauge.
Can I just hook up my compressor to the #3 cylinder while at Tdc to listen for leakage at carb, tailpipe, or pcv?
If so, how much psi on compressor?
Old Aug 31, 2012 | 11:48 AM
alexchavel's Avatar
alexchavel
So i hooked up my compressor with the #3 cylinder at TDC and I can hear/feel air rushing out of the top of the carburetor!
burnt/bent intake valve?
I have someone locally here who is selling some new aftermarket 302 heads, thinking of swapping old ones out, get em fixed later.
Considering this is an econoline van, not a mustang/race car, what should I be looking for as replacement heads? going to see them later today, don't know if they are performance heads or .....
