Axle Code = "97" Is this LS or not?
Old May 13, 2003 | 10:25 PM
jcandrew's Avatar
jcandrew
If an axle code on the door label is 97 on a 2X4 2000 Ford Ranger is this LS or not?
Old May 13, 2003 | 10:32 PM
LxMan1's Avatar
LxMan1
Usually, it will be a letter and a number if it is LS. Mine is H9 = 3.55 Traction-Lok. Check the rearend tag that is bolted under one of the rear pan bolts. It will have a number(usually on the bottom row,starting next to the bolt head) that will look something like 3 L 55. This would be a 3.55 Traction-Lok. If it just has 3 55, then it is a standard open rearend.
Jimmy
Old May 13, 2003 | 10:45 PM
jcandrew's Avatar
jcandrew
I am beginning to think that I don't have an LS as the first number on the differential tag reads: 9330A, and the second number reads: 10 88 0629. I think I have a 4.10 differential...no "L" in the numbers.
LV Dan
Jun 6, 2017 08:52 AM
brentkhack
21
Jul 17, 2014 07:27 PM
PStruwing
1997 - 2003 F150
Oct 30, 2012 12:57 AM
bigdaddyII
2004 - 2008 F150
Jan 23, 2012 05:47 PM
byro01
Jul 12, 2009 06:48 AM
