Sponsored by: Auxito
Brake Problems
Old Aug 23, 2012 | 01:29 PM
ethan1590's Avatar
ethan1590
Exclamation Brake Problems
2001 F350 with 5.4
No leaking brake lines. The bad calipers have been replaced. Brake system doesnt seem to build pressure when the truck is running. The pedal gets stiff when the truck is shut off but when its started the pedal goes to the floor. Just put in a new booster and master cylinder. Flushed and blead all the lines several times now and got all the air out and am now getting a nice solid stream of fluid. Any ideas?
Old Aug 23, 2012 | 03:30 PM
Lime1GT's Avatar
Lime1GT
Disc brakes on the rear? Did you check the rear caliper slide pins for seizing. They take a lot of severe weather abuse.
Old Aug 23, 2012 | 03:48 PM
Club Wagon's Avatar
Club Wagon
Suggest you move this to Super Duty Heavy Duty section.
Originally Posted by ethan1590
2001 F350 with 5.4
Any ideas?
"F350" has different brakes than F150.
Old Aug 26, 2012 | 06:26 PM
swest21's Avatar
swest21
Brake problems
I have the same issue on my 2002 FX4. Had a leak on a rear brake line and thought that might have been the problem. After having it replaced the mechanic could not get the brakes to bleed up. he replaced the master twice and eventualy put my old one back on because he couldn't get it to pressure up. He stated that there is a hydraulic assembley by the peddel that was bad.
Has antone encountered this before? Is he correct?
ethan1590
Aug 23, 2012 01:56 PM
nhf72003
Apr 8, 2011 09:44 PM
dpuff
15
Nov 14, 2006 10:49 AM
JoeVB
Jul 31, 2005 09:28 AM
msfprobass
Mar 6, 2003 06:35 PM
