Truck is a '73 F350 SCS w/ 390 engine. We ran in to a big problem last year where the truck back fired and bent several of the push rods which causes 2 of the lifters to pop out of place. Intake, carb, distributor, etc all had to be removed to fix.
Anyway, to make a long story short I need some help with one of the vacuum lines on the carb. I'll attach a picture and the piece in question is circled in red. What is this for? I cannot remember if this was connected before or not but now it's causing a huge vacuum leak. There is nothing on the air breather that attaches here either. The air breather on the truck is the one that you put oil in it. There is nothing on the bottom of it that goes in to this hole so the hole is wide open.
That's the fresh-air intake for the hot-air choke. It literally goes straight to the nipple underneath that you have plugged off. Therefore it is not causing any sort of vacuum leak and your problem is elsewhere.
I did put a vacuum line on that nipple. The line goes to a brass T thing on the intake near the pass side valve cover. After reading your post I'm thinking that line shouldn't go there. I'll have to see if I can find another spot for it. I'm not the one who took these lines off so I am not sure where they go.
It's kinda hard to read: What's the tag number on the carb, D4UE-HA? If so, it's for a 1974 non CA Econoline w/a 302.
That's not my carb. It's just one I found on the internet.
I got it figured out though. Nothing is supposed to go on that nipple. There are after market headers on the truck and the fresh air intake part isn't there. There's just the hot air tube and it hangs down by the header.
The vacuum hose I had on the nipple on the carb was actually supposed to go on this metal tube near the firewall.
